Date/Time: Sat, 12 Jul 2025 07:09:30 +0000
Different questions reg. Auto Trading Replay Backtest
View Count: 1314
[2014-12-28 11:46:20] |
sbsierra - Posts: 71 |
For me it seems not to be possible to use the function "Trade > AutoTrade System Replay BackTest" to run a backtest of all charts of a chartbook concurrently. this would make backtesting much more efficient. Please tell me if there is a simple way to do that or please implement this it. I read in older threads that it will not be possible to run one backtest with the use of multiple cores of a cpu. I understand that and agree with you opinion. the above mentioned procedure would run every backtest with a only one core. Please tell me if there is a chance that this will be possible and being implemented. have a great start to the new year. bs.trader |
[2014-12-29 04:06:28] |
You need to manually start the replay back test following the instructions here: Auto Trade System Back Testing: Replay Back Testing - Manual Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-29 10:21:41] |
I know how to manually start the replay, but this method is not as comfortable as using "Trade > AutoTrade System Replay BackTest". However it seems that manually replay does also support only one core.
