Date/Time: Tue, 21 Apr 2026 23:39:09 +0000
Export tick by tick data from Sierra
View Count: 2198
[2014-12-28 00:05:07]
FerroTrader - Posts: 72
is it possible to export tick by tick data from Sierra ? My data provider is IQFeed.
I would like to export to a TXT file my data.
Thank you
Andrew
[2014-12-29 04:03:48]
Yes. Refer to the documentation on this page:
Exporting and Importing Intraday Data Files
For further support, log into this Support Board using the same Account Name you are using with Sierra Chart. The easiest way to login is with Help >> Support Board.
Date Time Of Last Edit: 2014-12-29 04:04:55
