Date/Time: Sat, 12 Jul 2025 00:31:04 +0000
Monday's pivot points of gold and crude oil ridiculously appear to be same as Friday's which ref
View Count: 1051
[2014-12-26 15:09:25] |
gold757 - Posts: 39 |
lect Thursday' data. How can I bring out Monday's pivot points of gold and oil so that they reflect Friday's data, not Thursday...? All other days are ok,but Mon only is problem.
Date Time Of Last Edit: 2014-12-26 15:14:10
[2014-12-26 19:27:17] |
What is the exact name of the study you are using? And tell us the settings of each of the Inputs for the study. To access the Input settings, refer to the documentation here: Chart Studies: Adding/Modifying Chart Studies And post an image of the chart showing the period of time in question by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Also we highly recommend looking at the documentation for the study on this page: Technical Studies Reference Good chance you can determine the problem on your own. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
