Date/Time: Wed, 26 Mar 2025 08:40:29 +0000
[User Discussion] - Visual Studio 2013
View Count: 991
[2014-12-24 20:43:44] |
User447466 - Posts: 1 |
Can Visual Studio 2013 Community Edition be used in place of Visual Studio 2010 C++ Express? 2010 is getting a bit long in the tooth.
[2014-12-24 21:42:29] |
We are not sure about this. We do not use that version. We assume so. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-25 12:50:46] |
ehlaban - Posts: 50 |
I use MS Visual Studio Express 2013 for Sierra Chart development and i works just as the 2010 version.
[2014-12-27 21:02:21] |
User93199 - Posts: 3 |
Sierra chart . So what version do you use to compile the code ? point me to appropriate documentation ?
