Date/Time: Sun, 28 Apr 2024 09:23:19 +0000
[Feature Request] Menu/Toolbar buttons with Elliott Wave Numbers/Letters
View Count: 1334
[2014-12-22 13:34:07] |
User471104 - Posts: 2 |
Dear SierraChart Developers/Support, Amongst others I like putting a couple of 1-2-3-4-5 s (or i-ii-iii-iv-iv) and A-B-Cs into my charts. It's a small helping aid when I look at what the price could do next. One thing I believe could be interesting for SierraChart is to have a menu to allow the characters to be automatically selected to be pasted into the chart. Something like: -Elliott Wave -- Primary Level --- I --- II --- III --- IV --- V --- (A) --- (B) --- (C) -- Secondary Level --- 1 --- 2 --- 3 --- 4 --- 5 --- A --- B --- C -- Third Level --- i --- ii --- iii --- iv --- v --- a --- b --- c The menus (hopefully) could, like the other menu options, also be added to a toolbar to speed up adding counts to a chart. The depicted hierarchy is only an example and of course the amount of defined levels can be greater (those from Prechter could be used) for those who really wish to count from the smalles microwave to the largest supercycle wave. This feature would be a one time addition which could appeal to many of the counters either casual like myself or professional like others. Best regards |
[2014-12-22 18:45:06] |
This capability already exists. It was added for another user. You can add ToolBar buttons which can be configured to place specific text on the chart. This is configured through Global Settings >> Customize ToolBars >> ToolBar # >> Available ToolBar Commands >> Tools - Custom Text Drawing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-22 18:45:31
[2014-12-22 19:30:41] |
Thank you for the answer. It was not obvious for me ... already configured some buttons in a toolbar. Best regards |
[2015-07-30 12:01:18] |
bwalks123 - Posts: 122 |
Are you able to convert these custom text toolbar buttons into keyboard shortcuts?
[2015-07-30 16:58:28] |
Yes we can do that.
