Date/Time: Tue, 24 May 2022 05:55:15 +0000
Horizontal line
View Count: 1458
[2013-05-20 22:39:02] |
user85017 - Posts: 37 |
Hello, When i add horizontal line on the chart and go to properties to the line,i can only display the price so can you add a way to write a name too and if it's possible to put all in one rectangle Thanks |
[2013-05-21 00:55:36] |
The procedure to set a label on the line is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#VerticalandHorizontalLines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-21 05:20:42] |
it's ok to add text but i can not change the vertical align (see attachment)
Date Time Of Last Edit: 2013-05-21 05:29:41
[2013-05-22 16:26:29] |
Hello any answer ?
[2013-05-23 05:20:48] |
This would mean that is not supported.
[2013-05-24 05:48:01] |
Sorry but in documentation, there is the way to do it so maybe can you just activate this option if it's possible Thanks Adding Text to a Horizontal Line To add text to an existing horizontal line on the chart, right-click with your mouse pointer on this horizontal line and select Modify Text on the displayed menu. Enter the text in the displayed window and press OK. You will then see this text displayed under the horizontal line. You can change the alignment of the text through the Chart Drawing Properties. When you move the horizontal line, the text will not appear as you are moving the line, but after you set the line at the new location, you will see the text displayed again. |
