Date/Time: Fri, 10 May 2024 10:32:17 +0000
LMax Commissions
View Count: 1189
[2014-12-16 07:13:31] |
User78442 - Posts: 260 |
Hi, I'm looking at trading on LMax FX in SIM mode. I've set the commission rate @ 0.05 for a RT on the basis of the Lmax commssions of $25/Million and the units for SC & Lmax being in 1000's (1/100 of a Lot) - a 500 Unit trade i.e. $500,000 shows a commission of $0.21 ?? It should be $25 - Any ideas?
[2014-12-16 18:29:14] |
What is the symbol you are trading?
[2014-12-17 08:37:01] |
I figured it out
