Date/Time: Sat, 11 May 2024 14:43:06 +0000
[User Discussion] - Does not work historical chart
View Count: 806
[2014-12-15 20:14:17] |
User52538 - Posts: 11 |
... on all instruments - empty screen or 1-2 bars. By changing historical to intraday chart type in settings everything is ok.
[2014-12-15 20:18:30] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-15 23:50:46] |
Historical & intraday attached
historical.png / V - Attached On 2014-12-15 23:49:42 UTC - Size: 132.63 KB - 335 views intraday.png / V - Attached On 2014-12-15 23:49:46 UTC - Size: 135.7 KB - 320 views |
