Date/Time: Sun, 12 May 2024 10:28:41 +0000
OEX Fix keeps logging me out
View Count: 1107
[2014-12-15 18:27:32] |
GCAdmin - Posts: 35 |
Can't connect to OEC. I have since updated my SC Software, still unable to connect. It's not the weekend and I don't see that my account is locked. I read everything here http://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem and am contacting OEC right now, just wanted to make sure its not an SC problem. Software version: 1206 | 2014-12-15 10:41:32 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-15 10:41:32 Active service: Open E Cry FIX | 2014-12-15 10:41:32 Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-15 10:41:32 2014-12-15 10:41:32 Local computer clock time | 2014-12-15 10:41:32 2014-12-15 17:41:32 GMT time | 2014-12-15 10:41:32 2014-12-15 10:41:32 Time zone adjusted time | 2014-12-15 10:41:32 Time difference to server time: 7 seconds. | 2014-12-15 10:41:32 Program path: C:\Users\TIm\Desktop\GreenChart\ | 2014-12-15 10:41:32 Data Files path: C:\GreenChart\Data\ | 2014-12-15 10:41:32 OS Version Number: 6.2 | 2014-12-15 10:41:32 Locale Information: C | 2014-12-15 10:41:32 Checking for new symbol settings for oec | 2014-12-15 10:41:32 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2014-12-15 10:41:32 HTTP connection to www.sierrachart.com:80 (1324) | Connected. | 2014-12-15 10:41:33 Symbol settings are up-to-date for oec | 2014-12-15 10:41:33 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:38 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:38 HTTP connection to www.sierrachart.com:80 (1324) | Closed. No error. | 2014-12-15 10:41:38 HTTP connection to www.sierrachart.com:80 (1324) | Shutdown and closed. | 2014-12-15 10:41:38 OEC FIX Trading socket (1992) | Connected. | 2014-12-15 10:41:38 OEC FIX Trading socket (1992) | Starting SSL connection. | 2014-12-15 10:41:38 OEC FIX Trading socket (1992) | SSL connection established. | 2014-12-15 10:41:39 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:39 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:39 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:39 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:39 OEC FAST Data socket (1324) | Connected. | 2014-12-15 10:41:40 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:41:40 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:41:40 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:41:40 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:40 OEC FAST Data socket (1324) | Shutdown and closed. | 2014-12-15 10:41:40 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:41:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:40 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:41:40 Disconnected from Open E Cry. | 2014-12-15 10:41:40 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:40 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:40 OEC FIX Trading socket (1992) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:40 OEC FIX Trading socket (1992) | SSL has been shut down. | 2014-12-15 10:41:40 OEC FIX Trading socket (1992) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:40 OEC FIX Trading socket (1992) | Shutdown and closed. | 2014-12-15 10:41:40 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:40 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:43 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | Connected. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | Starting SSL connection. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | SSL connection established. | 2014-12-15 10:41:43 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:43 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:43 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:43 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:43 OEC FAST Data socket (2012) | Connected. | 2014-12-15 10:41:43 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:41:43 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:41:43 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:41:43 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:43 OEC FAST Data socket (2012) | Shutdown and closed. | 2014-12-15 10:41:43 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:41:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:43 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:41:43 Disconnected from Open E Cry. | 2014-12-15 10:41:43 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:43 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | SSL has been shut down. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:43 OEC FIX Trading socket (2020) | Shutdown and closed. | 2014-12-15 10:41:43 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:43 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:46 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:46 OEC FIX Trading socket (2020) | Connected. | 2014-12-15 10:41:46 OEC FIX Trading socket (2020) | Starting SSL connection. | 2014-12-15 10:41:46 OEC FIX Trading socket (2020) | SSL connection established. | 2014-12-15 10:41:46 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:47 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:47 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:47 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:47 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:47 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:47 OEC FIX Trading socket (2020) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:47 OEC FIX Trading socket (2020) | SSL has been shut down. | 2014-12-15 10:41:47 OEC FIX Trading socket (2020) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:47 OEC FIX Trading socket (2020) | Shutdown and closed. | 2014-12-15 10:41:47 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:47 OEC FAST Data socket (2016) | Shutdown and closed. | 2014-12-15 10:41:47 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:41:47 Disconnected from Open E Cry. | 2014-12-15 10:41:47 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:47 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:50 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:50 Intraday data recording state for symbol ESH5 is set to pending. | 2014-12-15 10:41:50 OEC FIX Trading socket (2064) | Connected. | 2014-12-15 10:41:50 OEC FIX Trading socket (2064) | Starting SSL connection. | 2014-12-15 10:41:50 HD Request # 2 | Downloading Intraday chart data for ESH5 to the file ESH5.scid. Service: oec | 2014-12-15 10:41:50 HD Request # 2 | Download start Date-Time: 2014-12-12 10:55:07.0 | 2014-12-15 10:41:50 HD Request # 2 | Using server: oec.sierracharts.com port 10149 | 2014-12-15 10:41:50 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-12-15 10:41:50 Socket (2112) | Connected. | 2014-12-15 10:41:50 HD Request # 2 | Sending historical data logon request message. | 2014-12-15 10:41:50 OEC FIX Trading socket (2064) | SSL connection established. | 2014-12-15 10:41:50 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:51 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:51 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:51 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:51 OEC FAST Data socket (2120) | Connected. | 2014-12-15 10:41:51 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:41:51 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:41:51 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:41:51 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:51 OEC FAST Data socket (2120) | Shutdown and closed. | 2014-12-15 10:41:51 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:41:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:51 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:41:51 Disconnected from Open E Cry. | 2014-12-15 10:41:51 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:51 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:51 OEC FIX Trading socket (2064) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:51 OEC FIX Trading socket (2064) | SSL has been shut down. | 2014-12-15 10:41:51 OEC FIX Trading socket (2064) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:51 OEC FIX Trading socket (2064) | Shutdown and closed. | 2014-12-15 10:41:51 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:51 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-12-12 10:55:07. Record interval: 1. Symbol: ESH5 | 2014-12-15 10:41:51 HD Request # 2 | Historical data for ESH5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-12-15 10:41:51 Socket (2112) | Shutdown and closed. | 2014-12-15 10:41:51 The network socket for historical data has been closed. | 2014-12-15 10:41:51 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5 | 2014-12-15 10:41:51 HD Request # 2 | Intraday download COMPLETE for ESH5. Completion time: 1s. Unique request ID: 1 | 2014-12-15 10:41:51 Removed historical data download ID 1 | 2014-12-15 10:41:51 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:54 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | Connected. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | Starting SSL connection. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | SSL connection established. | 2014-12-15 10:41:54 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:54 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:54 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:54 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:54 OEC FAST Data socket (2120) | Connected. | 2014-12-15 10:41:54 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:41:54 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:41:54 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:41:54 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:54 OEC FAST Data socket (2120) | Shutdown and closed. | 2014-12-15 10:41:54 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:41:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:54 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:41:54 Disconnected from Open E Cry. | 2014-12-15 10:41:54 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:54 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | SSL has been shut down. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:54 OEC FIX Trading socket (2016) | Shutdown and closed. | 2014-12-15 10:41:54 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:54 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\GreenChart\Data\ESH5.dly | 2014-12-15 10:41:57 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\GreenChart\Data\ESH5.dly | 2014-12-15 10:41:57 Chart #3 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #3 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #3 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #3 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #3 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #3 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #4 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:41:58 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:58 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #3 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #3 has tagged chart #2 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #3 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #2 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #3 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 OEC FIX Trading socket (2080) | Connected. | 2014-12-15 10:41:58 OEC FIX Trading socket (2080) | Starting SSL connection. | 2014-12-15 10:41:58 Historical data service client indicated that downloads are not enabled for data type. | 2014-12-15 10:41:58 Historical data service client indicated that downloads are not enabled for data type. | 2014-12-15 10:41:58 Chart #2 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 Chart #2 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:58 OEC FIX Trading socket (2080) | SSL connection established. | 2014-12-15 10:41:58 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:41:58 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:41:59 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:41:59 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:41:59 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:41:59 OEC FIX Trading socket (2080) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:41:59 OEC FIX Trading socket (2080) | SSL has been shut down. | 2014-12-15 10:41:59 OEC FIX Trading socket (2080) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:41:59 OEC FIX Trading socket (2080) | Shutdown and closed. | 2014-12-15 10:41:59 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:41:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:41:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:41:59 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:41:59 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #3 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #3 has tagged chart #2 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #3 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 OEC FAST Data socket (2080) | Connected. | 2014-12-15 10:41:59 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:41:59 Chart #2 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #2 has tagged chart #5 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 OEC FAST Data: Sending a Logout message. | 2014-12-15 10:41:59 Disconnected from Open E Cry. | 2014-12-15 10:41:59 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:41:59 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:41:59 OEC FAST Data socket (2080) | Closed. No error. | 2014-12-15 10:41:59 OEC FAST Data socket (2080) | Shutdown and closed. | 2014-12-15 10:41:59 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-12-15 10:41:59 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #5 has tagged chart #1 for full recalculation. Chartbook: Echo ESZ3.cht | 2014-12-15 10:41:59 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Echo ESZ3.cht | 2014-12-15 10:42:00 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:02 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:02 OEC FIX Trading socket (2192) | Connected. | 2014-12-15 10:42:02 OEC FIX Trading socket (2192) | Starting SSL connection. | 2014-12-15 10:42:02 OEC FIX Trading socket (2192) | SSL connection established. | 2014-12-15 10:42:02 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:02 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:02 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:02 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:02 OEC FAST Data socket (600) | Connected. | 2014-12-15 10:42:02 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:02 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:03 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:42:03 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:03 OEC FAST Data socket (600) | Shutdown and closed. | 2014-12-15 10:42:03 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:03 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:03 Disconnected from Open E Cry. | 2014-12-15 10:42:03 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:03 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:03 OEC FIX Trading socket (2192) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:03 OEC FIX Trading socket (2192) | SSL has been shut down. | 2014-12-15 10:42:03 OEC FIX Trading socket (2192) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:03 OEC FIX Trading socket (2192) | Shutdown and closed. | 2014-12-15 10:42:03 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:03 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:06 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | Connected. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | Starting SSL connection. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | SSL connection established. | 2014-12-15 10:42:06 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:06 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:06 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:06 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:06 OEC FAST Data socket (2100) | Connected. | 2014-12-15 10:42:06 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:06 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:06 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:42:06 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:06 OEC FAST Data socket (2100) | Shutdown and closed. | 2014-12-15 10:42:06 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:06 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:06 Disconnected from Open E Cry. | 2014-12-15 10:42:06 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:06 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | SSL has been shut down. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:06 OEC FIX Trading socket (2192) | Shutdown and closed. | 2014-12-15 10:42:06 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:06 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:09 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:09 OEC FIX Trading socket (2192) | Connected. | 2014-12-15 10:42:09 OEC FIX Trading socket (2192) | Starting SSL connection. | 2014-12-15 10:42:09 OEC FIX Trading socket (2192) | SSL connection established. | 2014-12-15 10:42:09 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:10 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:10 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:10 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:10 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:10 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:10 OEC FIX Trading socket (2192) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:10 OEC FIX Trading socket (2192) | SSL has been shut down. | 2014-12-15 10:42:10 OEC FIX Trading socket (2192) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:10 OEC FIX Trading socket (2192) | Shutdown and closed. | 2014-12-15 10:42:10 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:10 OEC FAST Data socket (1992) | Shutdown and closed. | 2014-12-15 10:42:10 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:10 Disconnected from Open E Cry. | 2014-12-15 10:42:10 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:10 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:13 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | Connected. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | Starting SSL connection. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | SSL connection established. | 2014-12-15 10:42:13 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:13 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:13 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:13 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:13 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:13 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | SSL has been shut down. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:13 OEC FIX Trading socket (2180) | Shutdown and closed. | 2014-12-15 10:42:13 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:13 OEC FAST Data socket (2176) | Shutdown and closed. | 2014-12-15 10:42:13 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:13 Disconnected from Open E Cry. | 2014-12-15 10:42:13 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:13 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:16 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:16 OEC FIX Trading socket (1992) | Connected. | 2014-12-15 10:42:16 OEC FIX Trading socket (1992) | Starting SSL connection. | 2014-12-15 10:42:16 OEC FIX Trading socket (1992) | SSL connection established. | 2014-12-15 10:42:16 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:17 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:17 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:17 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:17 OEC FAST Data socket (2192) | Connected. | 2014-12-15 10:42:17 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:17 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:17 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:17 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:17 OEC FAST Data socket (2192) | Shutdown and closed. | 2014-12-15 10:42:17 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:17 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:17 Disconnected from Open E Cry. | 2014-12-15 10:42:17 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:17 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:17 OEC FIX Trading socket (1992) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:17 OEC FIX Trading socket (1992) | SSL has been shut down. | 2014-12-15 10:42:17 OEC FIX Trading socket (1992) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:17 OEC FIX Trading socket (1992) | Shutdown and closed. | 2014-12-15 10:42:17 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:17 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:20 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:20 OEC FIX Trading socket (1948) | Connected. | 2014-12-15 10:42:20 OEC FIX Trading socket (1948) | Starting SSL connection. | 2014-12-15 10:42:20 OEC FIX Trading socket (1948) | SSL connection established. | 2014-12-15 10:42:20 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:20 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:20 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:20 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:20 OEC FAST Data socket (600) | Connected. | 2014-12-15 10:42:20 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:20 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:20 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:20 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:20 OEC FAST Data socket (600) | Shutdown and closed. | 2014-12-15 10:42:20 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:20 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:20 Disconnected from Open E Cry. | 2014-12-15 10:42:20 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:20 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:21 OEC FIX Trading socket (1948) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:21 OEC FIX Trading socket (1948) | SSL has been shut down. | 2014-12-15 10:42:21 OEC FIX Trading socket (1948) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:21 OEC FIX Trading socket (1948) | Shutdown and closed. | 2014-12-15 10:42:21 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:21 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:23 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:23 OEC FIX Trading socket (2100) | Connected. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | Starting SSL connection. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | SSL connection established. | 2014-12-15 10:42:24 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:24 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:24 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:24 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:24 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:24 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | SSL has been shut down. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:24 OEC FIX Trading socket (2100) | Shutdown and closed. | 2014-12-15 10:42:24 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:24 OEC FAST Data socket (600) | Shutdown and closed. | 2014-12-15 10:42:24 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:24 Disconnected from Open E Cry. | 2014-12-15 10:42:24 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:24 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:27 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:27 OEC FIX Trading socket (2100) | Connected. | 2014-12-15 10:42:27 OEC FIX Trading socket (2100) | Starting SSL connection. | 2014-12-15 10:42:27 OEC FIX Trading socket (2100) | SSL connection established. | 2014-12-15 10:42:27 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:27 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:27 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:27 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:27 OEC FAST Data socket (1992) | Connected. | 2014-12-15 10:42:27 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:27 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:28 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:28 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:28 OEC FAST Data socket (1992) | Shutdown and closed. | 2014-12-15 10:42:28 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:28 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:28 Disconnected from Open E Cry. | 2014-12-15 10:42:28 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:28 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:28 OEC FIX Trading socket (2100) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:28 OEC FIX Trading socket (2100) | SSL has been shut down. | 2014-12-15 10:42:28 OEC FIX Trading socket (2100) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:28 OEC FIX Trading socket (2100) | Shutdown and closed. | 2014-12-15 10:42:28 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:28 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:31 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | Connected. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | Starting SSL connection. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | SSL connection established. | 2014-12-15 10:42:31 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:31 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:31 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:31 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:31 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:31 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | SSL has been shut down. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:31 OEC FIX Trading socket (736) | Shutdown and closed. | 2014-12-15 10:42:31 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:31 OEC FAST Data socket (2180) | Shutdown and closed. | 2014-12-15 10:42:31 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:31 Disconnected from Open E Cry. | 2014-12-15 10:42:31 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:31 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:34 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:34 OEC FIX Trading socket (2184) | Connected. | 2014-12-15 10:42:34 OEC FIX Trading socket (2184) | Starting SSL connection. | 2014-12-15 10:42:34 OEC FIX Trading socket (2184) | SSL connection established. | 2014-12-15 10:42:34 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:34 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:34 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:34 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:34 OEC FAST Data socket (1324) | Connected. | 2014-12-15 10:42:35 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:35 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:35 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:35 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:35 OEC FAST Data socket (1324) | Shutdown and closed. | 2014-12-15 10:42:35 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:35 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:35 Disconnected from Open E Cry. | 2014-12-15 10:42:35 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:35 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:35 OEC FIX Trading socket (2184) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:35 OEC FIX Trading socket (2184) | SSL has been shut down. | 2014-12-15 10:42:35 OEC FIX Trading socket (2184) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:35 OEC FIX Trading socket (2184) | Shutdown and closed. | 2014-12-15 10:42:35 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:35 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:38 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | Connected. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | Starting SSL connection. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | SSL connection established. | 2014-12-15 10:42:38 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:38 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:38 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:38 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:38 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:38 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | SSL has been shut down. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:38 OEC FIX Trading socket (2184) | Shutdown and closed. | 2014-12-15 10:42:38 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:38 OEC FAST Data socket (1324) | Shutdown and closed. | 2014-12-15 10:42:38 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:38 Disconnected from Open E Cry. | 2014-12-15 10:42:38 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:38 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:41 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:41 OEC FIX Trading socket (2036) | Connected. | 2014-12-15 10:42:41 OEC FIX Trading socket (2036) | Starting SSL connection. | 2014-12-15 10:42:41 OEC FIX Trading socket (2036) | SSL connection established. | 2014-12-15 10:42:41 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:42 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:42 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:42 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:42 OEC FAST Data socket (1324) | Connected. | 2014-12-15 10:42:42 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:42 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:42 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:42 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:42 OEC FAST Data socket (1324) | Shutdown and closed. | 2014-12-15 10:42:42 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:42 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:42 Disconnected from Open E Cry. | 2014-12-15 10:42:42 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:42 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:42 OEC FIX Trading socket (2036) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:42 OEC FIX Trading socket (2036) | SSL has been shut down. | 2014-12-15 10:42:42 OEC FIX Trading socket (2036) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:42 OEC FIX Trading socket (2036) | Shutdown and closed. | 2014-12-15 10:42:42 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:42 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:45 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | Connected. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | Starting SSL connection. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | SSL connection established. | 2014-12-15 10:42:45 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:45 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:45 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:45 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:45 OEC FAST Data socket (2032) | Connected. | 2014-12-15 10:42:45 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:45 OEC FIX Trading: Received a Logout message. Text = Locked | 2014-12-15 10:42:45 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | SSL has been shut down. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:45 OEC FIX Trading socket (1196) | Shutdown and closed. | 2014-12-15 10:42:45 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:45 OEC FAST Data: Sending a Logout message. | 2014-12-15 10:42:45 Disconnected from Open E Cry. | 2014-12-15 10:42:45 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:45 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:45 OEC FAST Data socket (2032) | Closed. No error. | 2014-12-15 10:42:45 OEC FAST Data socket (2032) | Shutdown and closed. | 2014-12-15 10:42:45 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-12-15 10:42:45 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:48 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:48 OEC FIX Trading socket (2032) | Connected. | 2014-12-15 10:42:48 OEC FIX Trading socket (2032) | Starting SSL connection. | 2014-12-15 10:42:48 OEC FIX Trading socket (2032) | SSL connection established. | 2014-12-15 10:42:49 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:49 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:49 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:49 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:49 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:49 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:49 OEC FIX Trading socket (2032) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:49 OEC FIX Trading socket (2032) | SSL has been shut down. | 2014-12-15 10:42:49 OEC FIX Trading socket (2032) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:49 OEC FIX Trading socket (2032) | Shutdown and closed. | 2014-12-15 10:42:49 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:49 OEC FAST Data socket (1196) | Shutdown and closed. | 2014-12-15 10:42:49 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:42:49 Disconnected from Open E Cry. | 2014-12-15 10:42:49 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:49 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:52 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | Connected. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | Starting SSL connection. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | SSL connection established. | 2014-12-15 10:42:52 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:52 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:52 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:52 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:52 OEC FAST Data socket (1192) | Connected. | 2014-12-15 10:42:52 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:52 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:52 OEC FIX Trading: Received a Logout message. Text = Locked | 2014-12-15 10:42:52 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | SSL has been shut down. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:52 OEC FIX Trading socket (2044) | Shutdown and closed. | 2014-12-15 10:42:52 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:52 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:52 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:52 OEC FAST Data socket (1192) | Shutdown and closed. | 2014-12-15 10:42:52 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:52 Disconnected from Open E Cry. | 2014-12-15 10:42:52 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:52 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:55 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:55 OEC FIX Trading socket (1192) | Connected. | 2014-12-15 10:42:55 OEC FIX Trading socket (1192) | Starting SSL connection. | 2014-12-15 10:42:55 OEC FIX Trading socket (1192) | SSL connection established. | 2014-12-15 10:42:56 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:56 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:56 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:56 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:56 OEC FAST Data socket (2032) | Connected. | 2014-12-15 10:42:56 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:42:56 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:42:56 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:42:56 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:42:56 OEC FAST Data socket (2032) | Shutdown and closed. | 2014-12-15 10:42:56 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:42:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:42:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:42:56 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:42:56 Disconnected from Open E Cry. | 2014-12-15 10:42:56 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:42:56 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:42:56 OEC FIX Trading socket (1192) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:42:56 OEC FIX Trading socket (1192) | SSL has been shut down. | 2014-12-15 10:42:56 OEC FIX Trading socket (1192) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:42:56 OEC FIX Trading socket (1192) | Shutdown and closed. | 2014-12-15 10:42:56 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:42:56 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:42:59 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:59 OEC FIX Trading socket (2180) | Connected. | 2014-12-15 10:42:59 OEC FIX Trading socket (2180) | Starting SSL connection. | 2014-12-15 10:42:59 OEC FIX Trading socket (2180) | SSL connection established. | 2014-12-15 10:42:59 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:42:59 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:42:59 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:42:59 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:42:59 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:00 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:00 OEC FIX Trading socket (2180) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:00 OEC FIX Trading socket (2180) | SSL has been shut down. | 2014-12-15 10:43:00 OEC FIX Trading socket (2180) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:00 OEC FIX Trading socket (2180) | Shutdown and closed. | 2014-12-15 10:43:00 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:00 OEC FAST Data socket (1044) | Shutdown and closed. | 2014-12-15 10:43:00 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:00 Disconnected from Open E Cry. | 2014-12-15 10:43:00 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:00 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:03 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | Connected. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | Starting SSL connection. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | SSL connection established. | 2014-12-15 10:43:03 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:03 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:03 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:03 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:03 OEC FAST Data socket (2192) | Connected. | 2014-12-15 10:43:03 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:43:03 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:43:03 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:43:03 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:03 OEC FAST Data socket (2192) | Shutdown and closed. | 2014-12-15 10:43:03 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:43:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:03 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:43:03 Disconnected from Open E Cry. | 2014-12-15 10:43:03 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:03 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | SSL has been shut down. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:03 OEC FIX Trading socket (2044) | Shutdown and closed. | 2014-12-15 10:43:03 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:03 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:06 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:06 OEC FIX Trading socket (2040) | Connected. | 2014-12-15 10:43:06 OEC FIX Trading socket (2040) | Starting SSL connection. | 2014-12-15 10:43:06 OEC FIX Trading socket (2040) | SSL connection established. | 2014-12-15 10:43:06 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:07 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:07 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:07 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:07 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:07 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:07 OEC FIX Trading socket (2040) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:07 OEC FIX Trading socket (2040) | SSL has been shut down. | 2014-12-15 10:43:07 OEC FIX Trading socket (2040) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:07 OEC FIX Trading socket (2040) | Shutdown and closed. | 2014-12-15 10:43:07 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:07 OEC FAST Data socket (2044) | Shutdown and closed. | 2014-12-15 10:43:07 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:07 Disconnected from Open E Cry. | 2014-12-15 10:43:07 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:07 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:10 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | Connected. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | Starting SSL connection. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | SSL connection established. | 2014-12-15 10:43:10 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:10 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:10 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:10 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:10 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:10 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | SSL has been shut down. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:10 OEC FIX Trading socket (1044) | Shutdown and closed. | 2014-12-15 10:43:10 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:10 OEC FAST Data socket (2044) | Shutdown and closed. | 2014-12-15 10:43:10 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:10 Disconnected from Open E Cry. | 2014-12-15 10:43:10 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:10 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:13 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:13 OEC FIX Trading socket (1044) | Connected. | 2014-12-15 10:43:13 OEC FIX Trading socket (1044) | Starting SSL connection. | 2014-12-15 10:43:13 OEC FIX Trading socket (1044) | SSL connection established. | 2014-12-15 10:43:13 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:13 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:14 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:14 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:14 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:14 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:14 OEC FIX Trading socket (1044) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:14 OEC FIX Trading socket (1044) | SSL has been shut down. | 2014-12-15 10:43:14 OEC FIX Trading socket (1044) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:14 OEC FIX Trading socket (1044) | Shutdown and closed. | 2014-12-15 10:43:14 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:14 OEC FAST Data socket (1192) | Shutdown and closed. | 2014-12-15 10:43:14 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:14 Disconnected from Open E Cry. | 2014-12-15 10:43:14 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:14 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:17 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | Connected. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | Starting SSL connection. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | SSL connection established. | 2014-12-15 10:43:17 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:17 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:17 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:17 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:17 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:17 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | SSL has been shut down. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:17 OEC FIX Trading socket (1992) | Shutdown and closed. | 2014-12-15 10:43:17 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:17 OEC FAST Data socket (2044) | Shutdown and closed. | 2014-12-15 10:43:17 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:17 Disconnected from Open E Cry. | 2014-12-15 10:43:17 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:17 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:20 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:20 OEC FIX Trading socket (2044) | Connected. | 2014-12-15 10:43:20 OEC FIX Trading socket (2044) | Starting SSL connection. | 2014-12-15 10:43:20 OEC FIX Trading socket (2044) | SSL connection established. | 2014-12-15 10:43:20 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:20 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:20 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:20 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:20 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:21 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:21 OEC FIX Trading socket (2044) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:21 OEC FIX Trading socket (2044) | SSL has been shut down. | 2014-12-15 10:43:21 OEC FIX Trading socket (2044) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:21 OEC FIX Trading socket (2044) | Shutdown and closed. | 2014-12-15 10:43:21 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:21 OEC FAST Data socket (1992) | Shutdown and closed. | 2014-12-15 10:43:21 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:43:21 Disconnected from Open E Cry. | 2014-12-15 10:43:21 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:21 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:43:24 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | Connected. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | Starting SSL connection. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | SSL connection established. | 2014-12-15 10:43:24 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:43:24 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:43:24 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:43:24 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:43:24 OEC FAST Data socket (1044) | Connected. | 2014-12-15 10:43:24 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:43:24 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:43:24 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:43:24 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:43:24 OEC FAST Data socket (1044) | Shutdown and closed. | 2014-12-15 10:43:24 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:43:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:43:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:43:24 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:43:24 Disconnected from Open E Cry. | 2014-12-15 10:43:24 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:43:24 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | SSL has been shut down. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:43:24 OEC FIX Trading socket (2040) | Shutdown and closed. | 2014-12-15 10:43:24 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:43:24 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:46:24 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:46:24 OEC FIX Trading socket (1192) | Connected. | 2014-12-15 10:46:24 OEC FIX Trading socket (1192) | Starting SSL connection. | 2014-12-15 10:46:24 OEC FIX Trading socket (1192) | SSL connection established. | 2014-12-15 10:46:24 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:46:25 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:46:25 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:46:25 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:46:25 OEC FAST Data socket (2160) | Connected. | 2014-12-15 10:46:25 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:46:25 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:46:25 OEC FAST Data: Received a Logout message. Text = Locked | 2014-12-15 10:46:25 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:46:25 OEC FAST Data socket (2160) | Shutdown and closed. | 2014-12-15 10:46:25 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:46:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:46:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:46:25 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:46:25 Disconnected from Open E Cry. | 2014-12-15 10:46:25 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:46:25 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:46:25 OEC FIX Trading socket (1192) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:46:25 OEC FIX Trading socket (1192) | SSL has been shut down. | 2014-12-15 10:46:25 OEC FIX Trading socket (1192) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:46:25 OEC FIX Trading socket (1192) | Shutdown and closed. | 2014-12-15 10:46:25 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:46:25 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:49:25 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | Connected. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | Starting SSL connection. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | SSL connection established. | 2014-12-15 10:49:25 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:49:25 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:49:25 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:49:25 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:49:25 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:49:25 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | SSL has been shut down. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:49:25 OEC FIX Trading socket (2128) | Shutdown and closed. | 2014-12-15 10:49:25 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:49:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:49:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:49:25 OEC FAST Data socket (1192) | Shutdown and closed. | 2014-12-15 10:49:25 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:49:25 Disconnected from Open E Cry. | 2014-12-15 10:49:25 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:49:25 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:52:25 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:52:25 OEC FIX Trading socket (2096) | Connected. | 2014-12-15 10:52:25 OEC FIX Trading socket (2096) | Starting SSL connection. | 2014-12-15 10:52:25 OEC FIX Trading socket (2096) | SSL connection established. | 2014-12-15 10:52:25 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:52:26 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:52:26 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:52:26 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:52:26 OEC FAST Data socket (2208) | Connected. | 2014-12-15 10:52:26 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:52:26 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:52:26 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:52:26 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:52:26 OEC FAST Data socket (2208) | Shutdown and closed. | 2014-12-15 10:52:26 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:52:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:52:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:52:26 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:52:26 Disconnected from Open E Cry. | 2014-12-15 10:52:26 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:52:26 OEC FIX Trading: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:52:26 OEC FIX Trading socket (2096) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:52:26 OEC FIX Trading socket (2096) | SSL has been shut down. | 2014-12-15 10:52:26 OEC FIX Trading socket (2096) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:52:26 OEC FIX Trading socket (2096) | Shutdown and closed. | 2014-12-15 10:52:26 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:52:26 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:55:26 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:55:26 OEC FIX Trading socket (2128) | Connected. | 2014-12-15 10:55:26 OEC FIX Trading socket (2128) | Starting SSL connection. | 2014-12-15 10:55:26 OEC FIX Trading socket (2128) | SSL connection established. | 2014-12-15 10:55:26 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:55:26 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:55:27 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:55:27 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:55:27 OEC FAST Data socket (2224) | Connected. | 2014-12-15 10:55:27 OEC FAST Data: Sending the Hello message. | 2014-12-15 10:55:27 OEC FAST Data: Sending the Logon message. | 2014-12-15 10:55:27 OEC FAST Data: Received a Logout message. Text = InvalidUserOrPassword | 2014-12-15 10:55:27 OEC FAST Data: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:55:27 OEC FAST Data socket (2224) | Shutdown and closed. | 2014-12-15 10:55:27 OEC FAST Data: Logged out and disconnected. | 2014-12-15 10:55:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:55:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:55:27 OEC FIX Trading: Sending a Logout message. | 2014-12-15 10:55:27 Disconnected from Open E Cry. | 2014-12-15 10:55:27 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:55:27 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:55:27 OEC FIX Trading socket (2128) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:55:27 OEC FIX Trading socket (2128) | SSL has been shut down. | 2014-12-15 10:55:27 OEC FIX Trading socket (2128) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:55:27 OEC FIX Trading socket (2128) | Shutdown and closed. | 2014-12-15 10:55:27 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:55:27 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 10:58:27 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | Connected. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | Starting SSL connection. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | SSL connection established. | 2014-12-15 10:58:27 OEC FIX Trading: Sending the Logon message. | 2014-12-15 10:58:27 OEC FIX Trading | Connected to trading server. | 2014-12-15 10:58:27 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 10:58:27 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 10:58:27 OEC FIX Trading: Received a Logout message. | 2014-12-15 10:58:27 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | SSL has been shut down. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 10:58:27 OEC FIX Trading socket (1356) | Shutdown and closed. | 2014-12-15 10:58:27 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 10:58:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 10:58:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 10:58:27 OEC FAST Data socket (2068) | Shutdown and closed. | 2014-12-15 10:58:27 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 10:58:27 Disconnected from Open E Cry. | 2014-12-15 10:58:27 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 10:58:27 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 11:01:27 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 11:01:27 OEC FIX Trading socket (1196) | Connected. | 2014-12-15 11:01:27 OEC FIX Trading socket (1196) | Starting SSL connection. | 2014-12-15 11:01:27 OEC FIX Trading socket (1196) | SSL connection established. | 2014-12-15 11:01:27 OEC FIX Trading: Sending the Logon message. | 2014-12-15 11:01:28 OEC FIX Trading | Connected to trading server. | 2014-12-15 11:01:28 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 11:01:28 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 11:01:28 OEC FIX Trading: Received a Logout message. | 2014-12-15 11:01:28 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 11:01:28 OEC FIX Trading socket (1196) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 11:01:28 OEC FIX Trading socket (1196) | SSL has been shut down. | 2014-12-15 11:01:28 OEC FIX Trading socket (1196) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 11:01:28 OEC FIX Trading socket (1196) | Shutdown and closed. | 2014-12-15 11:01:28 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 11:01:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 11:01:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 11:01:28 OEC FAST Data socket (2044) | Shutdown and closed. | 2014-12-15 11:01:28 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 11:01:28 Disconnected from Open E Cry. | 2014-12-15 11:01:28 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 11:01:28 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-15 11:04:28 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | Connected. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | Starting SSL connection. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | SSL connection established. | 2014-12-15 11:04:28 OEC FIX Trading: Sending the Logon message. | 2014-12-15 11:04:28 OEC FIX Trading | Connected to trading server. | 2014-12-15 11:04:28 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 11:04:28 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 11:04:28 OEC FIX Trading: Received a Logout message. | 2014-12-15 11:04:28 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | SSL has been shut down. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | SSL object has been freed. SSL state is now disconnected. | 2014-12-15 11:04:28 OEC FIX Trading socket (1152) | Shutdown and closed. | 2014-12-15 11:04:28 OEC FIX Trading: Logged out and disconnected. | 2014-12-15 11:04:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-15 11:04:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-15 11:04:28 OEC FAST Data socket (2212) | Shutdown and closed. | 2014-12-15 11:04:28 OEC FAST Data: Socket connection was closed without any logout messages sent or received. | 2014-12-15 11:04:28 Disconnected from Open E Cry. | 2014-12-15 11:04:28 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-15 11:04:28 |
[2014-12-15 19:09:25] |
These are the relevant messages: OEC FIX Trading: Sending the Logon message. | 2014-12-15 11:01:28
OEC FIX Trading | Connected to trading server. | 2014-12-15 11:01:28 Open E Cry FIX | Connecting to prod.openecry.com:9301. | 2014-12-15 11:01:28 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-15 11:01:28 OEC FIX Trading: Received a Logout message. | 2014-12-15 11:01:28 OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-12-15 11:01:28 After Sierra Chart logs on to OEC, OEC logs you out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
