Date/Time: Fri, 10 May 2024 00:27:28 +0000
Gann Fan Tool will not turn off
View Count: 798
[2014-12-15 16:48:41] |
User75277 - Posts: 33 |
I went to the Tools menu and unchecked the GF but it will not un-check and no matter what I do a Gann Fan is written on the chart with any mouse contact tot he chart. Thanks for your help in advance.
[2014-12-15 19:39:26] |
You need to select another tool. Select Tools >> Pointer instead. This is how you disable a tool by selecting another one like the Pointer which by default does nothing.
