Date/Time: Fri, 10 May 2024 08:46:27 +0000
Connection
View Count: 786
[2014-12-15 10:20:45] |
Janos - Posts: 10 |
Hello, I tried to login today on v1210 and get this error message , then I upgraded to newest version - same thing - can not connect. What should I do now ? Now ok !!! Everything 100% . Solved. Date Time Of Last Edit: 2014-12-15 14:55:32
Capture11.PNG / V - Attached On 2014-12-15 10:18:33 UTC - Size: 98.86 KB - 312 views |
[2014-12-15 17:17:45] |
For future reference, for something like this contact your broker and have them put you in contact with TransAct support.
