Date/Time: Thu, 09 May 2024 01:44:50 +0000
loosing istorical data
View Count: 784
[2014-12-14 20:50:32] |
User596316 - Posts: 4 |
when I turn off computer or stand by i am loosing istorical data for the period off or stand by
[2014-12-14 20:55:53] |
This should not happen. Refer to help topic 7.1 here to download the missing data. Http://www.sierrachart.com/index.php?page=doc/helpdetails7.html If you do not get the historical data, then provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
