Date/Time: Mon, 13 May 2024 22:30:13 +0000
Accessing NumberBars from ACSIL
View Count: 923
[2014-12-14 16:39:03] |
User30995 - Posts: 2 |
As far as I have been able to understand from the ACSIL documentation it isn't possible to access information from the Number Bars in ACSIL. Is this correct? Would it be possible to add this to the ACSIL functions? I would like to automate a strategy using Number Bars. Cheers |
[2014-12-15 04:07:20] |
You can access the underlying data for Numbers Bars which we think should be sufficient for what you need. Use this ACSIL structure member: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scVolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-15 09:01:52] |
I went through the documentation and the example in studies7.cpp and it looks like I can use it for my purposes. Thanks!
