Date/Time: Mon, 06 May 2024 18:19:14 +0000
Data/Trade Service Settings-IQ
View Count: 831
[2014-12-14 04:15:00] |
User28366 - Posts: 14 |
1. What should be the correct HTTP SSL Proxy Port? Attached is the screen print of my settings = port 0 Attached is the screen print of Setup Instructions for IQFeed which shows - port 443. We know 443 is the correct port number when SSL is turned on. Where is the setting that establishes whether SSL or non-SSL is being utilized? 2. What is the correct or preferred Enable FIX Logging setting? Attached is the screen print of my settings - not checked Attached is the screen print of Setup Instructions for IQFeed which show - checked 3. Why does the sample shown in Setup Instructions show "Allow Support for Sierra Chart Data Feeds" - not checked? |
Data-Trade Service Settings-IQ-Attach 1_12-13-14.pdf - Attached On 2014-12-14 04:14:43 UTC - Size: 30.04 KB - 316 views Data-Trade Service Settings-IQ-Attach 2_12-13-14.pdf - Attached On 2014-12-14 04:14:52 UTC - Size: 28.71 KB - 304 views |
[2014-12-14 05:20:47] |
1, 2, 3. All of these settings are not used with IQ Feed. Disregard them.
