Date/Time: Sat, 11 May 2024 05:42:58 +0000
Non consisten time bars.
View Count: 733
[2014-12-13 02:25:40] |
Rhuz - Posts: 5 |
Hi SC. Is there a way to modify two charts so both of them have the same time period? The thing is that i'm not talking about fixed time bars. I would like to set a 2 renko ES chart and an Advance/Decline chart following the ES renko time period. As you know a renko bar could last from 2 seconds to 20 minutes and i would like to have both the same way. Thanks. |
[2014-12-15 10:13:13] |
Not sure if this is exactly what you are looking for but you can link charts so that they both have the same Bar Period. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
