Date/Time: Mon, 29 Apr 2024 00:58:08 +0000
What file stores the custom toolbar & tool config settings?
View Count: 1323
[2014-12-12 14:55:59] |
User641744 - Posts: 4 |
I've lost my custom toolbar/tool settings when upgrading or re-installing Sierra Chart and would like to back up this file(s). Thanks, -tom |
[2014-12-12 15:40:58] |
Sierra Chart - Max - Posts: 5597 |
Sierra3.cfg (Contains all of the global settings in Sierra Chart. This includes settings set through all of the configuration windows under the Global Settings menu including ToolBar configurations. Chart specific settings, like the settings in Chart >> Chart Settings, are held in Chartbooks and not this file. Sierra3.cfg does not include Account related settings or Global Symbol Settings and can be safely shared with others.) By default the file is already backed up to the Backups subfolder of your Sierra Chart installation. You should see it there with a number added to the name, you will need rename the file to remove the prefixing number before copying it back to the main Sierra Chart folder. Sierra Chart Support Date Time Of Last Edit: 2014-12-12 17:48:23
