Date/Time: Wed, 15 May 2024 02:01:18 +0000
[User Discussion] - TPO and candlestick bars
View Count: 1019
[2014-12-12 14:30:19] |
User99981 - Posts: 7 |
Hello, Onject : is it possible to see in the same graphe the studie TPO and the candlestick bars ? When i add studie "TPO Profile Chart" in a chart the candlestick disappear. How to see them ? Best regards |
[2014-12-12 20:18:07] |
No, this will not work properly. The two types of graphs are incompatible with each other on the time scale.
[2014-12-15 07:46:00] |
Thank you for your reply
