Date/Time: Tue, 07 May 2024 20:18:32 +0000
What Data Source to use for ETF Data
View Count: 1206
[2014-12-11 18:14:08] |
Laurent - Posts: 4 |
On checking all SC data sources, I was not able to find the ETF's for Direxion Daily Small Cap Bull 3X ETF (TNA) Direxion Daily Small Cap Bear 3X ETF (TZA) iShares Russell 2000 (IWM) What do I have to do to access the data streams for the above?? Laurent |
[2014-12-12 08:44:30] |
You can get this data with the Sierra Chart Exchange Data service: Sierra Chart Exchange Data Feed You will need to activate the "US Equities" exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-12 08:44:50
