Date/Time: Fri, 03 May 2024 05:39:26 +0000
Rollover Fail
View Count: 806
[2014-12-11 14:29:14] |
conr - Posts: 204 |
Reloaded my ES continuous charts for March contract and now it keeps freezing. Had to use Task Manager to close the program. Restarted and it appeared to be downloading with no problem. Green window popped up and said download complete. Clicked on chart and said not responding. Using SC Data.
[2014-12-11 15:13:37] |
conr - Posts: 204 |
Had to use the Task manager again to shut down. Restarted and the green historical download complete window stays on. The charts update but then freeze. This is a continuous thing every couple of minutes along with the message log window constantly appearing.
[2014-12-11 17:12:50] |
Follow the instructions here and delete the Intraday data file for the most recent 3 futures contracts for the ES: https://www.sierrachart.com/index.php?page=doc/doc_IntradayDataEditor.html#DeletingDataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
