Date/Time: Thu, 09 May 2024 01:23:03 +0000
Having trouble connecting to InteractiveBrokers!?
View Count: 2584
[2014-12-11 10:37:47] |
User59863 - Posts: 36 |
Could it be anything to do with HTTP SSL Proxy port? If so, can you suggest a different one? Message is below: ---------------------------------------------------------------- Connecting to IB data and trade server: 127.0.0.1. Port 7496. | 2014-12-11 05:21:11 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-11 05:21:12 Failed to connect to the data and trade server. | 2014-12-11 05:21:12 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-11 05:21:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-11 05:21:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-11 05:21:12 Disconnected from IB. | 2014-12-11 05:21:12 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-12-11 05:21:12 Starting TWS auto-login thread. | 2014-12-11 05:21:35 TWS auto-login thread ending. | 2014-12-11 05:21:35 ---------------------------------------------------------------- |
[2014-12-11 17:10:35] |
The HTTP SSL proxy is unrelated to this and is not used with Interactive Brokers. Refer to step 22 here: https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
