Date/Time: Fri, 03 May 2024 14:33:31 +0000
The Current Price Line?
View Count: 906
[2014-12-11 04:38:47] |
User93103 - Posts: 48 |
Hello: Most of my charts are set to start at 00:00:00 and end at 23:59:59. The Current Price Line has issue with the 45-minute break on each day. Next day, it draws a line from price point of the restart time (6:00 p.m.) to the price point time of 23:59:59 or 00:00:00, that is mostly diagonal based on the coordinates of price points. In order to eliminate that line, one has to go to the studies that are selected for each chart and click OK. Then, that line between the two points from the last day will disappear. It should be an easier way, please, help?! God Bless Thank you Ben |
[2014-12-11 06:53:25] |
There should not be a problem with this. What are the Input settings you have for the Current Price Line study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-11 22:21:24] |
Hello: Number of Bars to Display on. 0=Current Date 0 Input Data Last Display Current Price Line on Chart Bars Yes Forward Project Current Price Line NO Use Last Trade Price From Current Quote Data NO God Bless Thank you Ben |
[2014-12-12 00:11:04] |
This will be corrected in the next release.
