Date/Time: Sun, 05 May 2024 00:01:15 +0000
oec platform charts are not running correctly hardlyany bars for volume and tick charts
View Count: 857
[2014-12-11 03:10:21] |
User84455 - Posts: 32 |
time bars update when I disconnect and reconnect but not volume or ticks
[2014-12-11 04:38:54] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-11 05:13:02] |
http://www.sierrachart.com/image.php?l=141827463718.png here you go ,,, its showing very little for all others also |
[2014-12-11 07:12:50] |
We understand the source of the problem. There is not enough trading activity in the March 2015 contract, so go back to December 2014. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
