Date/Time: Sun, 28 Apr 2024 00:23:43 +0000
spikes on chart
View Count: 813
[2014-12-10 22:28:25] |
Ed Meckelborg - Posts: 71 |
I have huge out of range spikes on my chart. How do I fix them
[2014-12-10 22:47:09] |
Is this with a Historical Daily chart? If so, update Sierra Chart with Help >> Current Version. After the update, go to a chart that has an error and select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-10 23:08:48] |
no, it's on 5 min 10 min etc charts using IB
[2014-12-11 00:45:57] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
