Date/Time: Tue, 07 May 2024 04:13:41 +0000
Disable Menu Headers
View Count: 819
[2014-12-10 20:33:03] |
Fxxtrader - Posts: 79 |
Hello, is it possible to disable the menu items to help save space? Thanks. |
Attachment Deleted. menu header.png / V - Attached On 2014-12-10 20:32:45 UTC - Size: 193.99 KB - 298 views |
[2014-12-11 09:09:33] |
Yes. Refer to the Chart Menu documentation for this command and instructions.
