Date/Time: Thu, 02 May 2024 10:20:23 +0000
Bug - Stochastic Crossover
View Count: 1587
[2014-12-10 12:12:32] |
djcurcio - Posts: 236 |
The Stochastic Crossover does NOT retain the display of the last Buy and Sell prices. Rather it only displays the price Buy or Sell when that signal bar occurs. Also there is no documentation on how the buy / sell signals are generated. Are they generated when simply crossing the user-set buy / sell lines, or when the signal crosses in one direction and the crosses back in the opposite direction (latter preferred) |
[2014-12-12 21:39:12] |
Make sure you have enabled Always Show Name and Value Labels When Enabled in the Study Settings. We will be updating the documentation to explain how this study works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-12 21:39:44
[2014-12-13 09:56:59] |
The last Buy / Sell prices should be retained and displayed until a subsequent signal is generated.
[2014-12-14 00:55:53] |
They are. Refer to this image: http://www.sierrachart.com/image.php?l=1418518444224.png (This image is not available yet.. There is a problem we need to solve with image uploads) Here is the updated documentation: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s204 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-14 00:57:35
