Date/Time: Mon, 29 Apr 2024 08:00:59 +0000
Issues with FXCM FIX live
View Count: 783
[2014-12-09 15:31:50] |
EuropeanTrader - Posts: 290 |
Hi, please help me with the following. I use FXCM FIX for live cfd trading and on day one it worked ok, but today when I disable Sim and confirm that I want to trade live account in SC and when I try to put order in DOM, it doesnt happen, the DOM simply turns into a Sim mode. Why is that please? Thank you |
[2014-12-09 15:48:20] |
You need to set Global Settings >> Data/Trade Service Settings >> Service to FXCM FIX Trading.
[2014-12-09 16:05:02] |
yes, I just figured it out and wanted to send you a notice. I can't believe I overlooked it. Thank you |
