Date/Time: Mon, 06 May 2024 15:00:32 +0000
connecting to the internet
View Count: 816
[2014-12-09 14:14:13] |
User76992 - Posts: 1 |
I tried to change from the forex charts to the futures and it says that it is trying to re-connect and has not reconnected for over 24 hours. I tried rebooting, changing back to forex etc but nothing works.
[2014-12-09 15:29:12] |
Sierra Chart - Max - Posts: 5605 |
1. What Data or Trading service are you using or do you wish to use? See this page for the list: http://www.sierrachart.com/index.php?page=data.php&CAID=def Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. 2. Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support |
[2014-12-09 16:18:20] |
You need to set Global Settings >>Data/Trade Service Settings >> Service to SC Forex Data. Here are instructions: Sierra Chart Real Time and Historical Forex and CFD Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
