Date/Time: Thu, 02 May 2024 23:59:59 +0000
QM Charts not up dating
View Count: 813
[2014-12-08 17:37:56] |
Fozdick - Posts: 35 |
My QM charts are not drawing the bars. The price is moving up and down in the right hand price column. Delete and download works but will not update after that. Date Time Of Last Edit: 2014-12-08 17:38:54
[2014-12-08 17:52:24] |
We see you are using OEC, therefore most likely you have gone over the 5 symbol limit: https://www.sierrachart.com/index.php?page=doc/openecry.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
