Date/Time: Tue, 17 May 2022 13:17:00 +0000
Mass symbol change for SC?
View Count: 1174
[2013-05-19 22:57:21] |
Cy - Posts: 7 |
Does SC have a mass symbol change to change every chart open? Or say you have 20 charts and you must change the symbol for each chart?
[2013-05-20 03:17:39] |
joshtrader - Posts: 377 |
Look at Chart Linking.
[2013-05-21 02:08:12] |
This can be done by using Chart Linking: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
