Date/Time: Sat, 04 May 2024 19:58:58 +0000
Histogram
View Count: 1618
[2014-12-08 04:40:11] |
User93757 - Posts: 61 |
Hi, Is there a reason that Sierra Charts can not include Histogram on Draw Style? Or have i missed something? Study Settings -> Draw Style Thx, |
[2014-12-08 05:12:38] |
In Sierra Chart this Draw Style is called "Bar".
[2014-12-08 05:50:40] |
If I use "Bar", then Sierra will only chart the bar to draw above the "0 line". From my understanding, with a histogram, the (+ value) bars will be greater then "0 line" and the (- value) bars will be less then the "0 Line". ie. Can i create a histogram with the study "Volume" to look like the attached sample, ty |
Histogram.PNG / V - Attached On 2014-12-08 05:49:50 UTC - Size: 7.73 KB - 380 views |
[2014-12-08 08:36:35] |
Yes. This will work. When a Subgraph value at a particular chart column is negative, the line will go from 0 down to that negative value.
[2014-12-08 12:54:57] |
I suppose what i am trying to say, as an example; Can you take the current volume study and do this without modifying the study or using spreadsheets? The reason i ask; is because i imagine that this feature could be useful on many of the current studies. ty Date Time Of Last Edit: 2014-12-08 14:29:58
[2014-12-08 16:46:50] |
No, this does not make any sense. The volume study has positive numbers only.
[2014-12-08 17:42:08] |
Actually, we realize what you want to do. Here is the source code which will accomplish this: SCSFExport scsf_VolumeWithNegativeDownVolume(SCStudyInterfaceRef sc) { SCSubgraphRef Volume = sc.Subgraph[0]; if (sc.SetDefaults) { sc.GraphName = "Volume - With Negative Down Volume"; sc.ValueFormat = 0; sc.AutoLoop = true; sc.ScaleRangeType = SCALE_AUTO; Volume.Name = "Volume"; Volume.DrawStyle = DRAWSTYLE_BAR; Volume.PrimaryColor = RGB(0, 255, 0); Volume.SecondaryColor = RGB(255, 0, 0); Volume.SecondaryColorUsed = 1; Volume.LineWidth = 2; Volume.DrawZeros = false; sc.DisplayStudyInputValues = false; return; } if(sc.Close[sc.Index] >= sc.Open[sc.Index]) { Volume[sc.Index] = sc.Volume[sc.Index]; Volume.DataColor[sc.Index] = Volume.PrimaryColor; } else { Volume[sc.Index] = sc.Volume[sc.Index] * -1; Volume.DataColor[sc.Index] = Volume.SecondaryColor; } } To compile this, refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-08 18:47:47] |
Yes, this is the result i was suggesting. I understand the concept of pos & neg numbers. I guess what i am suggesting (not sure if it can be done) is to have a general setting in the studies or some type of overlay which can distinguish the difference between two colors (ie. green/red --> (sc.Close[sc.Index] >= sc.Open[sc.Index])).. And therefore draw positive and negative colored bars, based on this idea (histogram). If it can be done, i believe it could be very useful on a lot of the current studies out there. Thanks for entertaining the idea. I can always learn a bit of code to modify the current studies but i thought a lot of users would like such a feature; or not :) ty |
