Date/Time: Sun, 28 Apr 2024 21:49:51 +0000
sc.GetTradeListEntry ... missunderstanding?
View Count: 915
[2014-12-08 00:49:22] |
Kiwi - Posts: 374 |
I'm using it with SC version 1212. To get the tradelist entries from a chart it seems that >> trade >> show order fills must be ticked otherwise this doesn't return a value. s_ACSTrade TradeEntry; int Size = sc.GetTradeListSize(); if(Size > 0 && sc.GetTradeListEntry(Size - 1, TradeEntry)) { Do Stuff } If that is the case then is it possible to change this behaviour (logic being that selection to see marks on charts shouldn't affect the ability of an acsil function to test trade entries) ? Or am I missunderstanding its operation? |
[2014-12-08 01:14:08] |
This should not matter. Only make sure you set this: sc.MaintainTradeStatisticsAndTradesData = 1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
