Date/Time: Mon, 29 Apr 2024 02:35:40 +0000
FlattenAndCancelAllOrders on bar thas is not the last bar on the chart.
View Count: 882
[2014-12-06 02:50:32] |
onnb - Posts: 660 |
If FlattenAndCancelAllOrders is called on a bar that is not the last bar on the chart, will it flatten and cancel or will this be rejected? AutoLoop is enabled if it makes any difference. |
[2014-12-09 06:42:34] |
The documentation has been updated to explain the conditions under which the function call will be ignored: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#FlattenAndCancelAllOrders Specifically the answer to your question is no. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
