Date/Time: Fri, 03 May 2024 13:54:55 +0000
Disconnections AMP/CQG
View Count: 1066
[2014-12-05 15:06:26] |
User11942 - Posts: 298 |
Hi SC team, I've been experiencing multiple re-connections to AMP CQG service since 8:30 AM EST today and it keeps going. It has happened more than 10 times now(!!!). The problem appeared first this Monday once I updated to ver.1214. (Before that everything was OK, but it may be coincidence though). I see the same error message in the log every time a disconnection occurs. Websocket | Received opcode Close. Received status code: 65536000 | 2014-12-05 09:47:00
Is this a problem of SC? Or shall I contact AMP/CQG about that? Or should I blame my ISP? Please let me know the reason of disconnections. I attached entire log herein. There are no lost packets and tracing doesn't return errors. Thank you.
CQG FIX Trading | Websocket closed. | 2014-12-05 09:47:00 Connection to the external service has been lost. | 2014-12-05 09:47:00 CQG FIX Trading FIX: Sending a Logout message. | 2014-12-05 09:47:00 Sending logoff message. | 2014-12-05 09:47:00 Socket (1912) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-05 09:47:00 Socket (1912) | SSL has been shut down. | 2014-12-05 09:47:00 Socket (1912) | SSL object has been freed. SSL state is now disconnected. | 2014-12-05 09:47:00 Socket (1912) | Shutdown and closed. | 2014-12-05 09:47:00 CQG FIX Trading | Websocket closed. | 2014-12-05 09:47:00 CQG FIX Trading | Disconnected. | 2014-12-05 09:47:00 Will reconnect to the server in 5.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-05 09:47:00 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2014-12-05 09:47:01 socket (2172) | Shutdown and closed. | 2014-12-05 09:47:01 CQG FIX Trading FIX: Logged out and disconnected. | 2014-12-05 09:47:01 CQG FIX Trading FIX: Disconnected. | 2014-12-05 09:47:01 Date Time Of Last Edit: 2014-12-05 15:27:18
Private File |
[2014-12-05 18:33:29] |
This means that the CQG server intentionally closed the connection: Websocket | Received opcode Close. Received status code: 65536000 | 2014-12-05 09:47:00 Based upon what we have heard from CQG, this indicates a problem where the network connection is not able to handle the amount of data being sent. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-05 19:08:29] |
Thank you for the info.That sounds quite reasonable considering today's flows of data. Would it mean bandwidth or latency or general connection issues? I just read other thread with the same problem described where you mentioned possible fix by flagging overloads to CQG. Was that implemented? Does ver.1214 have that fix? |
[2014-12-05 19:12:51] |
We do not know. It is not possible for us to know. CQG might be able to give you a better answer.In the latest Sierra Chart version, there is a CQG specific option: Global Settings >> Data/Trade Service Settings >> Allow Server to Drop Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-05 19:13:31
[2014-12-05 19:16:47] |
Thanks. NVM. I think I discovered a root of the problem.
