Date/Time: Sat, 04 May 2024 03:28:08 +0000
Discrepancy between DOM / Chart DOM on Sierra and Broker platform
View Count: 853
[2014-12-05 09:59:52] |
Pawel_Szpak - Posts: 48 |
Have noticed this from around 2 days ago. If you look at the circled bid/offer amounts on the attached images. I have a difference in the amount on the ladder between my broker's execution platform and Sierra - but only at 1 price. Everything else agrees perfectly. It is always the price at either the current bid or current offer. The amount of difference varies, but seems to scale somewhat ie, the larger the amount on the bid/offer, the larger the difference will be. What could be causing this? |
ladder diff 1.png / V - Attached On 2014-12-05 09:50:47 UTC - Size: 200.86 KB - 335 views ladder diff2.png / V - Attached On 2014-12-05 09:58:42 UTC - Size: 330.02 KB - 334 views |
[2014-12-06 02:36:37] |
We have looked at how Sierra Chart processes the OEC market depth data and it is correct. So something is not right with the data from OEC.
