Date/Time: Fri, 03 May 2024 11:03:01 +0000
Numbers Bars and CQG
View Count: 834
[2014-12-05 06:18:58] |
rwilliams1 - Posts: 339 |
Does the Numbers Bars study work with Amp CQG? Everytime I try to use it, the chart goes blank.
[2014-12-05 06:43:23] |
Yes. However, it requires Sierra Chart service package 5. Although you should see candlesticks rather than Numbers Bars instead of the chart going blank if the service package is not on 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-05 06:44:00
