Date/Time: Mon, 06 May 2024 11:20:18 +0000
[User Discussion] - Technical Indicators
View Count: 1824
[2013-05-19 14:33:56] |
User38606 - Posts: 80 |
Dear Sierra, You have loads of technical indicators / studies available. I have never even heard of many of them before. I am looking for the best indicator that would help me find out whether the price is in congestion....Which one would you recommend?In other words, I am looking for a study that could show if the price is trending up or down or nowhere....i am more interested in nowhere...Thanks help! |
[2013-05-19 17:17:59] |
M5amhan - Posts: 468 |
moving avgs, try 35ema 20ema 5sma 3sma. when they are all in the correct order, then there is no chop. you are also gonna need to use multi time frames to see if its chopping around in the big picture or not.. however the most efficient way to determine if its chopping or not is just a knowledge of the market and candlesticks, no way around that Date Time Of Last Edit: 2013-05-20 01:01:28
[2013-05-20 21:44:54] |
Our recommendation is to look at the price chart and not bother with studies.
[2013-06-19 15:38:11] |
fyzuledu - Posts: 5 |
Dear sierra charts, I have set up Ichomoku Studies and would like to change the cloud color on Senkou A-B to to reflect bullish and bearish conditions. Is this possible, please? |
[2013-06-19 15:41:55] |
you can change the color of Span B fill bottom (to indicate bearish) Span A would represent bullish.. see attached image
Date Time Of Last Edit: 2013-06-19 15:46:53
indicator.PNG / V - Attached On 2013-06-19 15:40:56 UTC - Size: 37.69 KB - 615 views |
