Date/Time: Sun, 05 May 2024 16:26:03 +0000
OCO
View Count: 876
[2014-12-04 17:33:38] |
User71389 - Posts: 5 |
is there an easy way to have the OCO active like on ninja trader? I mean without having to choose among the big list of possible OCO types, I know that on ninja you only right click and activate OCO and thats about it, I am trying to find a simple way to do that on sierra but havent been able to figure that out. thanks |
[2014-12-04 18:06:43] |
If you are referring to OCO orders which are not Attached Orders, refer to the instructions here to submit them directly from the chart or Trade DOM: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#EnteringOCOOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-04 18:07:42
