Date/Time: Mon, 20 May 2024 01:27:13 +0000
Volume Profile Time Filter
View Count: 1012
[2014-12-03 19:48:35] |
AC95501 - Posts: 28 |
Dear SC-Community, I trade the ES here in Germany. When the US market opens here at 3.30pm, I want the volume profile on the chart and the DOM to be reset and start until market closing. How do I do that? Best regards Max |
[2014-12-03 21:16:18] |
Zosimus - Posts: 345 |
1. In the Chart Settings make sure that you have 2 sessions, one for the overnight session and for the RTH. 2. In he volume profile settings choose YES for "Use Separate Profile for Evening Session". this is documented here: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#DayEveningSeparateProfiles |
[2014-12-04 11:55:55] |
This is done through the Session Times settings in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-04 13:49:39] |
Thank you very much! It works well for the Chart. If I do the Same for the DOM, does the Volume Profile also only starts at the Session time? |
[2014-12-04 13:50:39] |
Yes.
[2014-12-04 16:21:13] |
Thanks.
