Date/Time: Fri, 03 May 2024 15:40:06 +0000
GC contract
View Count: 1042
[2014-12-03 12:45:46] |
michael baksheev - Posts: 27 |
Hey is any one else having problems bringing up the current gold contract GCG5 , it keeps saying erroro on system log any help would be great
[2014-12-03 16:30:12] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-04 12:00:07] |
Software version: 1214 | 2014-12-04 06:55:19 Uses Old Spreadsheets | 2014-12-04 06:55:19 Enabled for: Advanced Features. | 2014-12-04 06:55:19 Enabled for: Advanced Features 2. | 2014-12-04 06:55:19 Enabled for: Sierra Chart Historical Data Service. | 2014-12-04 06:55:19 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-04 06:55:19 Active service: TransAct Trading | 2014-12-04 06:55:19 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-04 06:55:19 2014-12-04 06:55:19 Local computer clock time | 2014-12-04 06:55:19 2014-12-04 11:55:19 GMT time | 2014-12-04 06:55:19 2014-12-04 06:55:19 Time zone adjusted time | 2014-12-04 06:55:19 Time difference to server time: 84 seconds. | 2014-12-04 06:55:19 WARNING: Your computer's clock is off by 84 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-12-04 06:55:19 Program path: C:\SierraChart\SierraChartTransActMA\ | 2014-12-04 06:55:19 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2014-12-04 06:55:19 OS Version Number: 5.1 | 2014-12-04 06:55:19 Locale Information: C | 2014-12-04 06:55:19 Checking for new symbol settings for ta | 2014-12-04 06:55:19 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-04 06:55:19 HTTP connection to www.sierrachart.com:80 (1448) | Connected. | 2014-12-04 06:55:19 Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:19 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:19 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:19 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:20 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:20 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:21 * Date rule based rollover from GCZ11 to next contract occurs at 2011-11-29. | 2014-12-04 06:55:21 Date rule based rollover from GCG12 to next contract occurs at 2012-01-30. | 2014-12-04 06:55:21 Date rule based rollover from GCJ12 to next contract occurs at 2012-03-29. | 2014-12-04 06:55:21 Date rule based rollover from GCM12 to next contract occurs at 2012-05-30. | 2014-12-04 06:55:21 Date rule based rollover from GCQ12 to next contract occurs at 2012-07-30. | 2014-12-04 06:55:21 Date rule based rollover from GCZ12 to next contract occurs at 2012-11-29. | 2014-12-04 06:55:21 Date rule based rollover from GCG13 to next contract occurs at 2013-01-30. | 2014-12-04 06:55:21 Date rule based rollover from GCJ13 to next contract occurs at 2013-03-28. | 2014-12-04 06:55:21 Date rule based rollover from GCM13 to next contract occurs at 2013-05-30. | 2014-12-04 06:55:21 Date rule based rollover from GCQ13 to next contract occurs at 2013-07-30. | 2014-12-04 06:55:21 Date rule based rollover from GCZ13 to next contract occurs at 2013-11-28. | 2014-12-04 06:55:21 Date rule based rollover from GCG14 to next contract occurs at 2014-01-30. | 2014-12-04 06:55:21 Date rule based rollover from GCJ14 to next contract occurs at 2014-03-28. | 2014-12-04 06:55:21 Date rule based rollover from GCM14 to next contract occurs at 2014-05-29. | 2014-12-04 06:55:21 Date rule based rollover from GCQ14 to next contract occurs at 2014-07-30. | 2014-12-04 06:55:21 Date rule based rollover from GCZ14 to next contract occurs at 2014-11-27. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCZ11 for the date range from 2011-07-28 to 2011-11-29. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCG12 for the date range from 2011-11-29 to 2012-01-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCJ12 for the date range from 2012-01-30 to 2012-03-29. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCM12 for the date range from 2012-03-29 to 2012-05-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCQ12 for the date range from 2012-05-30 to 2012-07-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCZ12 for the date range from 2012-07-30 to 2012-11-29. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCG13 for the date range from 2012-11-29 to 2013-01-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCJ13 for the date range from 2013-01-30 to 2013-03-28. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCM13 for the date range from 2013-03-28 to 2013-05-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCQ13 for the date range from 2013-05-30 to 2013-07-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCZ13 for the date range from 2013-07-30 to 2013-11-28. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCG14 for the date range from 2013-11-28 to 2014-01-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCJ14 for the date range from 2014-01-30 to 2014-03-28. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCM14 for the date range from 2014-03-28 to 2014-05-29. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCQ14 for the date range from 2014-05-29 to 2014-07-30. | 2014-12-04 06:55:21 Checking Daily data file for symbol GCZ14 for the date range from 2014-07-30 to 2014-12-04. | 2014-12-04 06:55:21 Performing historical Daily data download for symbol GCZ14 starting at 0. | 2014-12-04 06:55:21 GCZ14/GCZ4 [C] Daily #9 | Symbols used for continuous contract chart: | 2014-12-04 06:55:21 GCZ11 | 2014-12-04 06:55:21 GCG12 | 2014-12-04 06:55:21 GCJ12 | 2014-12-04 06:55:21 GCM12 | 2014-12-04 06:55:21 GCQ12 | 2014-12-04 06:55:21 GCZ12 | 2014-12-04 06:55:21 GCG13 | 2014-12-04 06:55:21 GCJ13 | 2014-12-04 06:55:21 GCM13 | 2014-12-04 06:55:21 GCQ13 | 2014-12-04 06:55:21 GCZ13 | 2014-12-04 06:55:21 GCG14 | 2014-12-04 06:55:21 GCJ14 | 2014-12-04 06:55:21 GCM14 | 2014-12-04 06:55:21 GCQ14 | 2014-12-04 06:55:21 GCZ14 | 2014-12-04 06:55:21 GCZ14/GCZ4 [C] Daily #9 | Waiting for historical downloads to complete with the IDs: 1, | 2014-12-04 06:55:21 Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:21 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:21 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:21 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:22 * Symbol settings are up-to-date for ta | 2014-12-04 06:55:22 Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:22 * HD Request # 2 | Downloading Historical Daily chart data for GCZ14. Starting date: 2014-12-02. Service: ta | 2014-12-04 06:55:22 Historical data download counter reset. | 2014-12-04 06:55:22 HD Request # 2 | Requesting historical Daily data for GCZ14 starting at 2014-12-01 | 2014-12-04 06:55:22 Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:22 * Intraday data recording state for symbol GCZ4 is set to download pending. | 2014-12-04 06:55:22 HD Request # 3 | Downloading Intraday chart data for GCZ4 to the file GCZ4.scid. Service: ta | 2014-12-04 06:55:22 HD Request # 3 | Download start Date-Time: 2014-12-03 07:11:49.0 | 2014-12-04 06:55:22 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2014-12-04 06:55:22 TransAct Trading | Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2014-12-04 06:55:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-12-04 06:55:22 Intraday data recording state for symbol GCG5 is set to download pending. | 2014-12-04 06:55:22 Intraday data recording state for symbol CLF5 is set to download pending. | 2014-12-04 06:55:22 Socket (2532) | Connected. | 2014-12-04 06:55:22 HD Request # 3 | Sending historical data logon request message. | 2014-12-04 06:55:22 HD Request # 2 | Receiving historical Daily data for GCZ14 starting at 2014-12-01 | 2014-12-04 06:55:23 Writing historical Daily data for GCZ14 to the file GCZ14.dly | 2014-12-04 06:55:23 HD Request # 2 | Received 4 records from 2014-12-01 00:00:00 to 2014-12-04 00:00:00 (4.0 days) and wrote 3 records for GCZ14 | 2014-12-04 06:55:23 HD Request # 2 | Daily download COMPLETE for GCZ14. Completion time: 1s. Unique request ID: 1 | 2014-12-04 06:55:23 Removed historical data download ID 1 | 2014-12-04 06:55:23 HD Request # 4 | Downloading Historical Daily chart data for CLF15. Starting date: 2014-12-02. Service: ta | 2014-12-04 06:55:23 HD Request # 4 | Requesting historical Daily data for CLF15 starting at 2014-12-01 | 2014-12-04 06:55:23 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-12-03 07:11:49. Record interval: 0. Symbol: GCZ4 | 2014-12-04 06:55:23 HD Request # 4 | Receiving historical Daily data for CLF15 starting at 2014-12-01 | 2014-12-04 06:55:23 Writing historical Daily data for CLF15 to the file CLF15.dly | 2014-12-04 06:55:23 HD Request # 4 | Received 4 records from 2014-12-01 00:00:00 to 2014-12-04 00:00:00 (4.0 days) and wrote 3 records for CLF15 | 2014-12-04 06:55:23 HD Request # 4 | Daily download COMPLETE for CLF15. Completion time: 0s. Unique request ID: 5 | 2014-12-04 06:55:23 Removed historical data download ID 5 | 2014-12-04 06:55:23 Socket (2532) | Shutdown and closed. | 2014-12-04 06:55:23 The network socket for historical data has been closed. | 2014-12-04 06:55:23 HD Request # 3 | Historical data for GCZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-12-04 06:55:23 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCZ4 | 2014-12-04 06:55:23 HD Request # 3 | Intraday download COMPLETE for GCZ4. Completion time: 1s. Unique request ID: 2 | 2014-12-04 06:55:23 Removed historical data download ID 2 | 2014-12-04 06:55:23 HD Request # 5 | Downloading Intraday chart data for GCG5 to the file GCG5.scid. Service: ta | 2014-12-04 06:55:23 HD Request # 5 | Header check failed: Unknown intraday file type. Failed to open the Intraday data file for download. | 2014-12-04 06:55:23 HD Request # 5 | Error downloading historical Intraday data for GCG5. Not downloading any Intraday data for symbol GCG5. | 2014-12-04 06:55:23 * HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCG5 | 2014-12-04 06:55:23 HD Request # 5 | Intraday download COMPLETE for GCG5. Completion time: 0s. Unique request ID: 3 | 2014-12-04 06:55:23 Removed historical data download ID 3 | 2014-12-04 06:55:23 HD Request # 6 | Downloading Intraday chart data for CLF5 to the file CLF5.scid. Service: ta | 2014-12-04 06:55:23 HD Request # 6 | Download start Date-Time: 2014-12-03 14:15:37.0 | 2014-12-04 06:55:23 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2014-12-04 06:55:23 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-12-04 06:55:24 Date rule based rollover from GCZ11 to next contract occurs at 2011-11-29. | 2014-12-04 06:55:24 Date rule based rollover from GCG12 to next contract occurs at 2012-01-30. | 2014-12-04 06:55:24 Date rule based rollover from GCJ12 to next contract occurs at 2012-03-29. | 2014-12-04 06:55:24 Date rule based rollover from GCM12 to next contract occurs at 2012-05-30. | 2014-12-04 06:55:24 Date rule based rollover from GCQ12 to next contract occurs at 2012-07-30. | 2014-12-04 06:55:24 Date rule based rollover from GCZ12 to next contract occurs at 2012-11-29. | 2014-12-04 06:55:24 Date rule based rollover from GCG13 to next contract occurs at 2013-01-30. | 2014-12-04 06:55:24 Date rule based rollover from GCJ13 to next contract occurs at 2013-03-28. | 2014-12-04 06:55:24 Date rule based rollover from GCM13 to next contract occurs at 2013-05-30. | 2014-12-04 06:55:24 Date rule based rollover from GCQ13 to next contract occurs at 2013-07-30. | 2014-12-04 06:55:24 Date rule based rollover from GCZ13 to next contract occurs at 2013-11-28. | 2014-12-04 06:55:24 Date rule based rollover from GCG14 to next contract occurs at 2014-01-30. | 2014-12-04 06:55:24 Date rule based rollover from GCJ14 to next contract occurs at 2014-03-28. | 2014-12-04 06:55:24 Date rule based rollover from GCM14 to next contract occurs at 2014-05-29. | 2014-12-04 06:55:24 Date rule based rollover from GCQ14 to next contract occurs at 2014-07-30. | 2014-12-04 06:55:24 Date rule based rollover from GCZ14 to next contract occurs at 2014-11-27. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCZ11 for the date range from 2011-07-28 to 2011-11-29. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCG12 for the date range from 2011-11-29 to 2012-01-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCJ12 for the date range from 2012-01-30 to 2012-03-29. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCM12 for the date range from 2012-03-29 to 2012-05-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCQ12 for the date range from 2012-05-30 to 2012-07-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCZ12 for the date range from 2012-07-30 to 2012-11-29. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCG13 for the date range from 2012-11-29 to 2013-01-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCJ13 for the date range from 2013-01-30 to 2013-03-28. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCM13 for the date range from 2013-03-28 to 2013-05-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCQ13 for the date range from 2013-05-30 to 2013-07-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCZ13 for the date range from 2013-07-30 to 2013-11-28. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCG14 for the date range from 2013-11-28 to 2014-01-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCJ14 for the date range from 2014-01-30 to 2014-03-28. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCM14 for the date range from 2014-03-28 to 2014-05-29. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCQ14 for the date range from 2014-05-29 to 2014-07-30. | 2014-12-04 06:55:24 Checking Daily data file for symbol GCZ14 for the date range from 2014-07-30 to 2014-12-04. | 2014-12-04 06:55:24 GCZ14/GCZ4 [C] Daily #9 | Symbols used for continuous contract chart: | 2014-12-04 06:55:24 GCZ11 | 2014-12-04 06:55:24 GCG12 | 2014-12-04 06:55:24 GCJ12 | 2014-12-04 06:55:24 GCM12 | 2014-12-04 06:55:24 GCQ12 | 2014-12-04 06:55:24 GCZ12 | 2014-12-04 06:55:24 GCG13 | 2014-12-04 06:55:24 GCJ13 | 2014-12-04 06:55:24 GCM13 | 2014-12-04 06:55:24 GCQ13 | 2014-12-04 06:55:24 GCZ13 | 2014-12-04 06:55:24 GCG14 | 2014-12-04 06:55:24 GCJ14 | 2014-12-04 06:55:24 GCM14 | 2014-12-04 06:55:24 GCQ14 | 2014-12-04 06:55:24 GCZ14 | 2014-12-04 06:55:24 Socket (2360) | Connected. | 2014-12-04 06:55:24 HD Request # 6 | Sending historical data logon request message. | 2014-12-04 06:55:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-12-04 06:55:24 Socket (2544) | Connected. | 2014-12-04 06:55:24 TransAct Trading | Connected to server. | 2014-12-04 06:55:24 TransAct Trading | Sending logon request message. | 2014-12-04 06:55:24 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-12-03 14:15:37. Record interval: 0. Symbol: CLF5 | 2014-12-04 06:55:25 HTTP connection to www.sierrachart.com:80 (1448) | Closed. No error. | 2014-12-04 06:55:25 HTTP connection to www.sierrachart.com:80 (1448) | Shutdown and closed. | 2014-12-04 06:55:25 HD Request # 6 | Historical data for CLF5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-12-04 06:55:25 Socket (2360) | Shutdown and closed. | 2014-12-04 06:55:25 The network socket for historical data has been closed. | 2014-12-04 06:55:25 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLF5 | 2014-12-04 06:55:25 HD Request # 6 | Intraday download COMPLETE for CLF5. Completion time: 2s. Unique request ID: 4 | 2014-12-04 06:55:25 Removed historical data download ID 4 | 2014-12-04 06:55:25 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-12-04 06:55:30 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-12-04 06:55:30 TransAct Trading | Successfully connected. Operation Successful. | 2014-12-04 06:55:30 TransAct Trading | Starting real-time market data updates for: CLF5. ID: 1 | 2014-12-04 06:55:30 Intraday data recording state for symbol CLF5 is set to download pending. | 2014-12-04 06:55:30 HD Request # 7 | Downloading Intraday chart data for CLF5 to the file CLF5.scid. Service: ta | 2014-12-04 06:55:30 HD Request # 7 | Download start Date-Time: 2014-12-03 14:15:37.0 | 2014-12-04 06:55:30 HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2014-12-04 06:55:30 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-12-04 06:55:30 TransAct Trading | Starting real-time market data updates for: GCZ4. ID: 2 | 2014-12-04 06:55:30 Intraday data recording state for symbol GCZ4 is set to download pending. | 2014-12-04 06:55:30 Symbol Error - GCZ4 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2014-12-04 06:55:30 TransAct Trading | Starting real-time market data updates for: GCG5. ID: 3 | 2014-12-04 06:55:30 Intraday data recording state for symbol GCG5 is set to download pending. | 2014-12-04 06:55:30 Socket (1448) | Connected. | 2014-12-04 06:55:31 HD Request # 7 | Sending historical data logon request message. | 2014-12-04 06:55:31 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-12-03 14:15:37. Record interval: 0. Symbol: CLF5 | 2014-12-04 06:55:31 HD Request # 7 | Decompressing data. | 2014-12-04 06:55:32 HD Request # 7 | Receiving Intraday data for CLF5 starting at 2014-12-03 14:15:37 | 2014-12-04 06:55:33 HD Request # 7 | Timestamp of first Intraday data file record written: 2014-12-03 14:15:39 | 2014-12-04 06:55:33 Socket (1448) | Shutdown and closed. | 2014-12-04 06:55:34 The network socket for historical data has been closed. | 2014-12-04 06:55:34 HD Request # 7 | Received 43540 records from 2014-12-03 14:15:37 to 2014-12-04 06:56:53 (16.7 hours) and wrote 43539 records for CLF5 | 2014-12-04 06:55:34 HD Request # 7 | Intraday download COMPLETE for CLF5. Completion time: 4s. Unique request ID: 6 | 2014-12-04 06:55:34 Removed historical data download ID 6 | 2014-12-04 06:55:34 Real-time Intraday chart data file updates started for CLF5 | 2014-12-04 06:55:34 HD Request # 8 | Downloading Intraday chart data for GCZ4 to the file GCZ4.scid. Service: ta | 2014-12-04 06:55:34 HD Request # 8 | Download start Date-Time: 2014-12-03 07:11:49.0 | 2014-12-04 06:55:34 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2014-12-04 06:55:34 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-12-04 06:55:34 Socket (1556) | Connected. | 2014-12-04 06:55:34 HD Request # 8 | Sending historical data logon request message. | 2014-12-04 06:55:34 Date rule based rollover from GCZ11 to next contract occurs at 2011-11-29. | 2014-12-04 06:55:34 Date rule based rollover from GCG12 to next contract occurs at 2012-01-30. | 2014-12-04 06:55:34 Date rule based rollover from GCJ12 to next contract occurs at 2012-03-29. | 2014-12-04 06:55:34 Date rule based rollover from GCM12 to next contract occurs at 2012-05-30. | 2014-12-04 06:55:34 Date rule based rollover from GCQ12 to next contract occurs at 2012-07-30. | 2014-12-04 06:55:34 Date rule based rollover from GCZ12 to next contract occurs at 2012-11-29. | 2014-12-04 06:55:34 Date rule based rollover from GCG13 to next contract occurs at 2013-01-30. | 2014-12-04 06:55:34 Date rule based rollover from GCJ13 to next contract occurs at 2013-03-28. | 2014-12-04 06:55:34 Date rule based rollover from GCM13 to next contract occurs at 2013-05-30. | 2014-12-04 06:55:34 Date rule based rollover from GCQ13 to next contract occurs at 2013-07-30. | 2014-12-04 06:55:34 Date rule based rollover from GCZ13 to next contract occurs at 2013-11-28. | 2014-12-04 06:55:34 Date rule based rollover from GCG14 to next contract occurs at 2014-01-30. | 2014-12-04 06:55:34 Date rule based rollover from GCJ14 to next contract occurs at 2014-03-28. | 2014-12-04 06:55:34 Date rule based rollover from GCM14 to next contract occurs at 2014-05-29. | 2014-12-04 06:55:34 Date rule based rollover from GCQ14 to next contract occurs at 2014-07-30. | 2014-12-04 06:55:34 Date rule based rollover from GCZ14 to next contract occurs at 2014-11-27. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCZ11 for the date range from 2011-07-28 to 2011-11-29. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCG12 for the date range from 2011-11-29 to 2012-01-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCJ12 for the date range from 2012-01-30 to 2012-03-29. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCM12 for the date range from 2012-03-29 to 2012-05-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCQ12 for the date range from 2012-05-30 to 2012-07-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCZ12 for the date range from 2012-07-30 to 2012-11-29. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCG13 for the date range from 2012-11-29 to 2013-01-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCJ13 for the date range from 2013-01-30 to 2013-03-28. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCM13 for the date range from 2013-03-28 to 2013-05-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCQ13 for the date range from 2013-05-30 to 2013-07-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCZ13 for the date range from 2013-07-30 to 2013-11-28. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCG14 for the date range from 2013-11-28 to 2014-01-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCJ14 for the date range from 2014-01-30 to 2014-03-28. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCM14 for the date range from 2014-03-28 to 2014-05-29. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCQ14 for the date range from 2014-05-29 to 2014-07-30. | 2014-12-04 06:55:34 Checking Daily data file for symbol GCZ14 for the date range from 2014-07-30 to 2014-12-04. | 2014-12-04 06:55:34 GCZ14/GCZ4 [C] Daily #9 | Symbols used for continuous contract chart: | 2014-12-04 06:55:34 GCZ11 | 2014-12-04 06:55:34 GCG12 | 2014-12-04 06:55:34 GCJ12 | 2014-12-04 06:55:34 GCM12 | 2014-12-04 06:55:34 GCQ12 | 2014-12-04 06:55:34 GCZ12 | 2014-12-04 06:55:34 GCG13 | 2014-12-04 06:55:34 GCJ13 | 2014-12-04 06:55:34 GCM13 | 2014-12-04 06:55:34 GCQ13 | 2014-12-04 06:55:34 GCZ13 | 2014-12-04 06:55:34 GCG14 | 2014-12-04 06:55:34 GCJ14 | 2014-12-04 06:55:34 GCM14 | 2014-12-04 06:55:34 GCQ14 | 2014-12-04 06:55:34 GCZ14 | 2014-12-04 06:55:34 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-12-03 07:11:49. Record interval: 0. Symbol: GCZ4 | 2014-12-04 06:55:35 HD Request # 8 | Decompressing data. | 2014-12-04 06:55:35 HD Request # 8 | Receiving Intraday data for GCZ4 starting at 2014-12-03 07:11:49 | 2014-12-04 06:55:35 HD Request # 8 | Timestamp of first Intraday data file record written: 2014-12-03 07:37:28 | 2014-12-04 06:55:35 Socket (1556) | Shutdown and closed. | 2014-12-04 06:55:35 The network socket for historical data has been closed. | 2014-12-04 06:55:35 HD Request # 8 | Received 197 records from 2014-12-03 07:11:49 to 2014-12-04 06:34:01 (23.4 hours) and wrote 195 records for GCZ4 | 2014-12-04 06:55:35 HD Request # 8 | Intraday download COMPLETE for GCZ4. Completion time: 1s. Unique request ID: 7 | 2014-12-04 06:55:35 Removed historical data download ID 7 | 2014-12-04 06:55:35 Real-time Intraday chart data file updates started for GCZ4 | 2014-12-04 06:55:35 HD Request # 9 | Downloading Intraday chart data for GCG5 to the file GCG5.scid. Service: ta | 2014-12-04 06:55:35 HD Request # 9 | Header check failed: Unknown intraday file type. Failed to open the Intraday data file for download. | 2014-12-04 06:55:35 HD Request # 9 | Error downloading historical Intraday data for GCG5. Not downloading any Intraday data for symbol GCG5. | 2014-12-04 06:55:35 * HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCG5 | 2014-12-04 06:55:35 HD Request # 9 | Error opening Intraday data files to add Time and Sales records. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. | 2014-12-04 06:55:35 * HD Request # 9 | Intraday download COMPLETE for GCG5. Completion time: 0s. Unique request ID: 8 | 2014-12-04 06:55:35 Removed historical data download ID 8 | 2014-12-04 06:55:35 Real-time Intraday chart data file updates started for GCG5 | 2014-12-04 06:55:35 Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:38 * CLF5 30 Min #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 11:00:00. Next Bar Date Time: 2014-12-03 10:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:38 CLF5 30 Min #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 13:00:00. Next Bar Date Time: 2014-12-03 12:30:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:39 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 11:00:00. Next Bar Date Time: 2014-12-03 10:50:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:39 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 11:10:00. Next Bar Date Time: 2014-12-03 11:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:39 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 11:20:00. Next Bar Date Time: 2014-12-03 11:10:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:39 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 12:50:00. Next Bar Date Time: 2014-12-03 12:40:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 13:00:00. Next Bar Date Time: 2014-12-03 12:50:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 13:10:00. Next Bar Date Time: 2014-12-03 13:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 CLF5 10 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 14:10:00. Next Bar Date Time: 2014-12-03 14:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 CLF5 60 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 11:00:00. Next Bar Date Time: 2014-12-03 10:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 CLF5 60 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-12-03 13:00:00. Next Bar Date Time: 2014-12-03 12:00:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\CLF5.scid | 2014-12-04 06:55:40 Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:45 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:45 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:45 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:47 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:48 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:49 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for reading. Error: Unknown intraday file type. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Unknown intraday file type. C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Error opening or reading chart data file. File: C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid | 2014-12-04 06:55:54 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:55:58 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:03 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:05 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:05 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:06 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:06 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:08 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:23 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:24 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:25 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:25 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:47 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:48 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:48 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:48 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:48 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:56:58 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:06 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:14 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:15 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:29 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:34 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:35 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:35 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:35 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:36 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:36 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:36 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:40 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:40 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:40 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:46 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:56 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:56 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:57:59 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:04 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:05 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:12 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:12 * Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:12 * |
[2014-12-04 18:01:19] |
We apologize for the delay. This indicates the GC data file is damaged: Header check failed when opening the file C:\SierraChart\SierraChartTransActMA\Data\GCG5.scid for adding records. Error: Unknown intraday file type. Failed to open the intraday data file for GCG5. | 2014-12-04 06:58:12 *
Follow these instructions to delete the Intraday data file: http://www.sierrachart.com/index.php?page=doc/doc_IntradayDataEditor.html#DeletingDataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
