Date/Time: Tue, 07 May 2024 23:14:14 +0000
Number Bars
View Count: 913
[2014-12-03 01:38:20] |
User41015 - Posts: 2 |
Is it possible to have a column where it shows the live "Bid &Ask? If yes, how do I put it on? |
[2014-12-03 02:02:41] |
Do you mean the prices themselves? That is on the top line of the chart and can be added through Global Settings >> Customize Chart Header.
[2014-12-03 03:05:21] |
NO, not on the top, I mean to the right of the developing candle bar |
[2014-12-03 03:31:38] |
Not the prices themselves. But you could enable Chart >>Show Bid and Ask Lines.
[2014-12-03 08:14:59] |
We just realized, that this capability does exist. It is part of the DOM Graph. This is the documentation for it here: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph There is an option for this in Chart >> Chart Settings >> Advanced Settings 2. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-03 08:19:25
[2014-12-04 13:59:19] |
User245469 - Posts: 6 |
Hi, Id like to put to my numberbars chart the chart with same symbol but smaller. So, in one big window another but smaller one
Capture_2014_12_04_14_55_25_386.png / V - Attached On 2014-12-04 13:57:01 UTC - Size: 82.28 KB - 375 views |
[2014-12-04 18:09:24] |
The only way this can be done is to overlay the price graph from one chart on another chart by using the Study/Price Overlay study. This assumes the chart bars are of different time periods between the two charts. Refer to help topic 28: http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
