Date/Time: Fri, 30 Oct 2026 15:11:28 +0000
Big difference on delta indicator.
View Count: 1531
[2014-12-02 18:11:15]
User83842 - Posts: 5
I have seen many times there is big difference between delta values and forms when im comparing my delta and my trading partner delta. We both use same data feed (FXCM) we have both same settings, but delta difference is huge.
Let me show you example here:
My delta picture: http://c2n.me/joFWeK.png
My trading partner delta: http://clip2net.com/s/joFm26
We both have 5min AudUsd chart and delta difference is huge.
What should i do to fix this problem?
Thanks,
Silver
[2014-12-02 21:48:24]
There are several things to check:
-Tick by tick data configuration:
http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
-Time zone:
http://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html
-Session Times:
http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php
All of these need to match.
And make sure that both copies of Sierra Chart are running an up-to-date version:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
In the case of the Forex markets, you can safely use Cumulative Delta Bars-Volume. This will give you a stable result when the historical data is not 1 trade per record. We strongly recommend using this study instead.
Date Time Of Last Edit: 2014-12-02 21:48:47
