Date/Time: Sat, 27 Apr 2024 22:24:44 +0000
Market profile current bracket incorrect
View Count: 881
[2014-12-02 17:35:49] |
User63632 - Posts: 43 |
YM market profile beginning with D bracket (30min) should be at "j" bracket and is only at "F" bracket 3hours into the day. All prior days have worked fine..Please advise Thank you |
[2014-12-02 18:01:20] |
The proper approach to analyzing and solving this problem is to make sure the letter code configuration and Session Times are correct: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#LetterCodes And the related TPO Profile Chart study settings. And then you need to remove the TPO Profile Chart study from the chart and check the underlying data to make sure there is no missing data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
