Date/Time: Sun, 05 May 2024 16:35:16 +0000
Total Volume traded at each price
View Count: 812
[2014-12-02 17:31:47] |
User38993 - Posts: 61 |
On the ladder I see total volume traded at each price, but it seems to start counting once I open up the dom. Is there anyways I can see previous volumes?
[2014-12-02 17:38:44] |
Therefore, what you are looking at is not the total traded volume. You have to look at the columns you have added to the trade DOM. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns What you want to use is the Volume by Price study instead: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#TradeDOMVolumeProfile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
