Date/Time: Mon, 06 May 2024 13:09:03 +0000
Hedging
View Count: 959
[2014-12-02 12:50:01] |
User79541 - Posts: 9 |
Hi, Is there a way to refer to two different accounts for the purpose of hedging on the spreadsheet for trading?
[2014-12-02 17:55:56] |
This would require 2 separate charts each using the Spreadsheet Trading study and each chart would need to be set to a different Trade Account. Each Spreadsheet Study on these charts could be referencing the same Spreadsheet and you can use cell references so that they can refer to each others data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
