Date/Time: Thu, 09 May 2024 02:22:19 +0000
Windows 8.1 - Sierra Chart loads slowly or not at all?
View Count: 887
[2014-12-01 21:08:19] |
jsoviero - Posts: 84 |
Hi all, I was warned prior to purchasing a new laptop with Windows 8.1. My chartbook is not loading or takes 10 minutes to load. Please advise if there a any fixes for this type of problem. Thank you in advance |
[2014-12-01 22:03:10] |
Most likely this is caused by anti-malware/antivirus software installed on the computer. We recommend removing it from the computer. For complete information refer to: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-01 22:03:27
