Date/Time: Fri, 03 May 2024 04:16:14 +0000
Save new DOM default quantities
View Count: 1024
[2014-12-01 19:04:45] |
rhovega - Posts: 279 |
Hi SC, Is it possible to save new default quantities in the DOM? Every time I open a DOM within a chartbook I need to manually change the default quantities. Many thanks |
[2014-12-02 00:54:00] |
Yes. This can be done with Trade Window Configurations: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
