Date/Time: Sun, 05 May 2024 18:24:10 +0000
Problem with SC data feed
View Count: 922
[2014-12-01 15:40:57] |
katek - Posts: 28 |
Hi, I am not receiving real-time data feed from Sierra Chart. I've checked the configuration on SC and on the profile, it seems correct. PS: It was working on Friday with the same config. |
[2014-12-01 15:43:25] |
katek - Posts: 28 |
I've noted that before the connection to IB is done, I can see the "M" in the chart title. As soon as connection to IB is done, the "M" disappears.
[2014-12-01 17:09:18] |
Make sure you are connecting to your Interactive Brokers Live account.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-01 17:09:33
