Date/Time: Sun, 28 Apr 2024 21:18:52 +0000
GetStudyArrayUsingID
View Count: 2302
[2013-03-25 15:37:28] |
SgtJ - Posts: 154 |
Is there a reason why I'm not able to capture the bid ask depth bars study data using GetStudyArrayUsingID? The custom study works fine when I substitute a different target study id. I'm using v952. I have accessed this data in the past fwiw. |
[2013-03-25 19:27:16] |
There should be no problem. Do you see the Bid Ask Depth Bars study show data at the time you are using sc.GetStudyArrayUsingID.
[2013-03-25 19:49:08] |
SgtJ - Posts: 154 |
Y, I see the values.
[2013-03-25 20:23:03] |
Are you looking at the end of the array retrieved with sc.GetStudyArrayUsingID. At the beginning of the array you will just see zeros most likely.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-25 20:23:18
[2013-03-25 20:38:16] |
SgtJ - Posts: 154 |
Just realized the issue. This study has 4 subgraphs, I was looking at sg1 instead of sg4. thx
