Date/Time: Sun, 05 May 2024 18:23:03 +0000
CQG with RCG
View Count: 875
[2014-11-28 10:57:24] |
Carl71 - Posts: 125 |
I have an account with RCG (Rosenthal Collins Group) and I use CQG Trader to place orders i would like to know if it would be possible to use Sierra Chart with CQG data at least for charting with my username and password TIA Date Time Of Last Edit: 2014-11-28 10:58:22
[2014-11-28 20:05:21] |
You will need to contact RCG about this. Let them know that Sierra Chart uses the CQG Web API to connect to CQG. Here are the set up instructions: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
