Date/Time: Sun, 28 Apr 2024 22:48:36 +0000
Custom DLL for screenshot uploading
View Count: 1460
[2014-11-27 21:00:04] |
User50579 - Posts: 6 |
Hello, it is possible to open the source code, which is used to send screenshots to your servers ? I would like to make DLL which will upload chart screenshots to vBulletin. Thanks. |
[2014-11-28 03:31:44] |
There is an ACSIL variable for saving a chart image to a file: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scSaveChartImageToFile If this does not meet your requirements, let us know what you would need. Possibly being able to change the filename? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
